Evil66
Banned
Hi Guys,
Got a problem with my L76 6L VZ SS not starting easily after being driven a bit earlier (say 1/2hr to 1 1/2 hrs earlier). Sometimes it will start after a bit of cranking, other times it times out on the autocrank feature and I have to crank it again before it will fire. Noticed the other day when it does eventually start that it blows a bit of black smoke (fuel). If I leave it until the next day it will start first kick. Car also has a very minor miss at idle but not that noticeabl and it drives fine from idle to redline.
Things I have done so far:
New plugs
New plug leads
Ultrasonic clean injectors and refit
New fuel filter
Swap a known good coil onto each cylinder and start car.
Test fuel pressure (fine at 58psi)
Plugged into EFI live - not showing any fault codes at all.
Has anyone ever had this sort of issue or got any ideas on what it might be?
Thanks
New plugs
New plug leads
New fuel filter
Thanks
