Loopy1978
- Jun 21, 2014
- 13
- 0
- 0
- Age
- 45
- Location
- Morayfield
- VZ Commodore Executive Wagon MY06 D/F
I know this has been covered and ive read a lot on this forum about it but i thought id share my current dilemma and hopefully get some ideas as to what the problem may be. When i first purchased a second hand VZ 2006 Executive Alloytec V6 back in September it wasn't long after i got the car i had the good ol powertrain error. Anyway i used to be able to disconnect the battery and clear it and it would go away for a while then when it came back id do the same thing (sometimes turning the car off and waiting a minute it would come good also). Anyway I kept persevering with this until i had a different code come up it was an SRS Airbag fault. No matter how many times i disconnected the battery or reset the computer it wouldn't go away. So i took it to a mechanic who put it on his laptop and couldn't find any hard coded errors (probably because i kept clearing it disconnecting the battery) . Anyway he cleared it with his laptop and reset the computer and everything was fine for about 3 months until all of a sudden my LCD display on my cluster crapped itself. It slowly started to fade in and out until it finally went black and I couldn't read or see anything or tell if it was on or not because everything looked on. Read up heaps about this and everything points to replacing the cluster...right. Anyway couldn't afford that and because all my manual instruments still worked and car hadn't thrown any errors for ages i just kept driving it until i could afford a new cluster.
UNTIL i had the powertrain error come back again today. I didn't know this at first because obviously i cant read the LCD as its all black just had the normal loss of power and orange engine light come on. This happened to me on a trip and stupid me had forgotten to leave a shifter or a 10mm spanner in the car and was in middle of nowhere without being able to reset the computer how i previously did to fix the problem. So i thought stuff it ill pull the main 60 amp fuse out and reset it that way. Anyway no matter how long i waited or reset the computer this way it wouldnt go away. The error would clear but as soon as i started driving bang engine light comes back on loss of power cars obviously in safety mode. At this point getting rather frustrated as wasn't 100% sure what error was as still cant read the cluster LCD. Any pulled over again and this time without turning the car off i just ripped the 60amp main fuse out and the 60amp engine main out and car stopped. As it should. Waited about 5 minutes then plugged them back in with key still on reds and walla magical fairy dust the LCD screen on the cluster starts working again. (so much for needing a new cluster) . Anyway now i could read the LCD it told me there was an ABS Fault. So i ripped the 60 amps out again with engine running and cleared computer again. Now i have no ABS fault error coming up at all but the powertrain warning keeps coming on and cars is always in safety mode. resetting computer via battery or pulling out 60 amps doesn't get rid of it. It has fixed my LCD display though. Now im no mechanic but im a computer IT Specialist (not cars jut normal computers) and what im starting to think from all the bullshit the computer is telling me and all the faulty codes its telling me plus the LCD display being how it was and could possibly still go and coming good again im thinking that the computer is probably corrupted, screwed or dodgy??? Any Ideas would be very helpful LOL. Im at my wits end with it LOL. Oh and just to add when the problem first arose before Christmas 2014 i always had a strong smell of fuel inside the cabin. Hadnt had that at all for ages but as soon as computer started throwing powertrain error again the strong smell of fuel is back
