JarBro
- Nov 30, 2014
- 32
- 2
- 0
- Location
- Karratha
- VZ Executive Wagon
Hi guys,
Just a question re guarding my temp gauge as it does not seem to move.
If I check in the on board dash it says it is sitting at 215 degrees when the car is cold. I can check all functions on the dash and the needle moves up.
As soon as I start the car both fans come on and stay on. I have replaced the temp sensor and checked resistance and voltage is around the 5v mark.
Not really sure what else you would check. I have to reset the ECU each time by taking the battery off to start it as I think it has a safety setting that won't let the car start.
I had a P0118 code if that helps.
Any ideas ?
Any ideas ?
