JarBro
- Nov 30, 2014
- 32
- 2
- 0
- Location
- Karratha
- VZ Executive Wagon
Hi guys codes I have coming up.
P2229 Barometric pressure sensor voltage high
P0343 Intake CMP sensor circuit high voltage (bank1)
P0348 Intake CMP sensor circuit high voltage (bank2)
P0521 Oil Pressure sensor range/performance
P0118 ECT sensor circuit high voltage
P0197 Engine oil temp low voltage
I am thinking this is a possible ECU problem and probably needs replacing, can any guru's confirm this off the given codes.
As for code P0118 this keeps my fans running from the time I start up and my temp needle does not even move off cold. Now when i reset the codes for about 2 seconds the fans stop running and my temp needle begins to rise before it trips out again and goes back to faulted.
So I assume all codes are resetting but in a matter of seconds they are all faulting again. Sounds like a bad ECU but just want second opinions please.
Thanks.
Thanks.
