mrjayviper
So I bought load resistors so I can use LED bulbs.
I just looked at the bulb socket and it seems there are 2x + terminals and 1x - terminal. Do I clipped 1 side of the resistor on both + terminals and the other on the negative or clipping on 1 + terminal is good enough?
I'm thinking only 1 wire is need as connecting 2x + wires would short the 2 wires. Thanks!
