- Feb 22, 2005
- 1,188
- 335
- 83
- Age
- 36
- Location
- Geelong
- '97 Caprice 355ci & VZ SS Ute
Hey boys
I have my VZ SS L98 ute play up on me Friday.
Was driving home @ 100ks. And the cruise control automatically flicked off and the engine light popped on. I pulled over, switched it off then realized i wasn’t safe enough over on the break down lane. So i went to start it and it cranked over alot of times before starting again. So i gave it some rev’s and looked at my taco and it wasn’t working. I jumped out and popped the bonnet. I saw the intake pipe was undone so i reconnected it and i started it and it started fine, everything worked so i drove home.
Then i was driving home Saturday and i was going around a round about and it started chugging half way around, like there was no fuel. Then it cleared up and the engine light popped on and once again i lost the tacho gauge. I switched it off and went to crank it again it did the crank over alot of times before firing up again
So i disconnected the battery, left it over night to reset the ecu. Next day i plugged it all back in. Took it for a spin and was giving it hell. It felt lively as normal. Then the engine light came on, tacho dropped while giving it ****. I babied it back to mine and when i got home i was revving it. and it sound like it back firing.
Now im not sure if its like a coil or if its actually a sensor. Has this happened to anyone? Im confused as to why the revs would drop all together.
