Fastmotion
- May 17, 2012
- 28
- 0
- 0
- Location
- Australia
- VT2 Clubsport R8
Posting for my Brother in Law,
Has a VZ V6 Alloytec Ute thats done 190k,
Tried to start it and the battery was flat, charged the battery, had it tested and the battery is perfect. It'll turn over normally but not fire. Called mobile mechanic who hooked it up to his small computer and found an issue with the ecu and bcm not linking. Couldn't fix it on his little machine. Checked the fuel pressure and there's definitely fuel coming through. Took it back to his workshop, hooked it up to the tech2 computer and managed to relink the bcm and ecu, continued testing and can't find any other issues. Has spark, and fuel and no leaks around the manifold at all.
As a last resort, He's going to do have a look at the timing on Monday to see if that's out by enough to cause the issue.
Ive seen another post about holding the accelerator and turning it over but not sure if that applys to this?
Anyone have any other thoughts or second opinions?, Timing chain has been quoted for a fairly decent amount to replace so want to be pretty sure thats it.
