Keithone
- Apr 7, 2015
- 34
- 0
- 6
- Age
- 64
- Location
- Hackham
- Commodore VY
As per previous posts I now have my vz back together after replacing valves due to low compression on cylinder one
I have filled the radiator with fluid and run the engine. On removing cap after engine cools I need to add more fluid.
I have done this three times and still it needs topping up.
This evening I placed a "topper" on the radiator inlet to try and remove any air.
I then replaced the cap and nipped to the shops for baccy(half an hour)
When i got back I found the top radiator hose had sucked in on itself. ( Hope this makes sense)
My concern is A) having to place more fluid.
And B) Why would the top hose constrict ?
I cant see any leaks at all and nothing out of the ordinary
Sorry if this has been mentioned before but I did do a search to no avail
