VZ Sway Bar D Bushes Size?
A9L
Donating Member
VZ Calais LS1
Some of you might remember the annoying rattle I was chasing. I've decided to get Holden to replace the strut top mount/bearings and install Nolathane "D" mounting bushes at the same time.
My question is, what size is the swaybar? I get 25.1mm with calipers along the straight part above the bash plate but Nolathane supply 24mm and 26mm. Part number on the swaybar is 92166401 so which is it? 24 or 26? No luck with Google. On VZ Calais LS1.
Thanks in advance
dgp
VF II SSV Redline
I suggest your measurement is correct, your Calais would have FE1 suspension.
A9L
Donating Member
VZ Calais LS1
Thanks, thought that was weird. So there is no Nolathane replacement then?
