captaindrewski
- Oct 11, 2011
- 19
- 0
- 0
- Location
- kalgoorlie
- vr commodore ss hsv enhanced
Hey there everybody been having a few dramas with an intermittent problem on my girlfriends car. It will drive fine for months on end then decide to stop on us. It has been stalling mainly at low speeds, sometimes directly after had issues starting again. . Also sometimes at highway speeds when you accelerate it sometimes has a miss, although im unsure if thats related. When the miss under acceleration got very bad- which i noticed when on holiday- i dont drive the car much myself and it rarely goes on the highway its just probably more noticeable there- i noticed that one of the air hoses next to the throttlebody was almost broken in half, so i did a bodgy repair with insulation tape which seemed to have fixed it. i have since replaced it with cut down coolant hose which fits quite well. but the problem has come back.
recently it wouldnt start so we connected a scan tool and found some codes- slip rings was one and can bus another. i checked the CAN BUS and got 60 ohms across terminals so seems ok.
Had the ignition lock replaced as the key was able to move away from the lock breaking contact with the slip ring which I thought could be why it was dropping out and reset all the codes with the scan tool. The next day it was stalling again and i got these codes.
P2088: intake camshaft position control solenoid circuit low voltage
P2092: intake camshaft position control solenoid circuit low voltage
P0261 : injector 1 control circuit low voltage
P0264 : injector 2 control circuit low voltage
P0267 : injector 3 control circuit low voltage
P0270 : injector 4 control circuit low voltage
P0273 : injector 5 control circuit low voltage
P0276 : injector 6 control circuit low voltage
P0458 :Evap Emission control system purge solenoid low voltage
I have not had any of these codes before apart from i think the P0458 which is the purge solenoid.I have a list written down from last time i checked codes but i will have to find it.
once cleared the codes didnt come back. I'm unsure what is causing this best guess is an intermittent bad earth/ dirty plug or at worst module failure?
