DanRondeau
Hi All, This is my first post so sorry if I am repeating a common question but I have a 05 VZ executive wagon that won't start. I have just bought it knowing that it won't start and am trying to figure it out. The car turns over like it will start but it won't fire up. I am getting the Check drive train message. I have checked fuel supply and it is fine, I have checked that all six cylinders are getting spark and they are. I have disconnected the battery to reset the computer and when I re connect the car tries to start, gives a splutter and then wont start. The next thing I am going to do is a compression test. What is a average range that the compression should be? I have taken it to a local mechanic who plugged his hand held reader into it and he said no fault codes are coming up. When I turn on the ignition the system check says System OK. I would greatly appreciate any leeds or advise from the group. Cheers Dan
