BillsCommodore
- Jan 12, 2014
- 11
- 0
- 0
- Location
- Australia
- VZ Executive
So, I did a bit of research and there seems to be some good advice in regards to the suspension setup for a track day setup, people are recommending
changing sway bars, changing bushings etc. I was wondering what people did in preparation for the track?
Personally I was thinking something along the lines of
your experiences (what parts did you change for the track? did you run a different alignment setup? maybe more caster, or negative camber?) any help would be greatly appreciated
I've got a track day coming up, just wondering other than alignment and tyres what can i do to get as much traction as possible and reduced body roll, given the car already has a set of shortened KYB shocks and SL-HD springs. I've got a 2005 V6 VZ Commodore, i was thinking rear cross member bushings, differential insert bushing and front and rear sway bars, should i be replacing the front control arm, and radius rod bushings too?
