Vz engine control relay burnt
Snickers89
Holden
What can be the cause of a engine control relay being burnt?
Benboy
Hill River, SA
2007 SVZ Wagon
When you say burn - I presume you mean electrically destroyed NOT a fire !!!
If NOT fire then perhaps an extreme voltage surge or short circuit.
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
if its the contacts that have slowly failed you end up with a poor connection and the condition gets worse from there, so extra heat higher contact resistance more heat etc
Snickers89
Holden
Wasn't exactly on fire but the outer shell of the relay did show signs of some type of overheating... Haven't opened it up yet tho
Snickers89
Holden
There wasn't any blown fuses or anything tho. That's got to be a positive right?
routier1642
64
Australia
2005 Adventra LX6
I had exactly the same situation 2 months ago. The casing of the ECU relay looked scorched.
Cause unknown!
I swapped it with the high beam relay (identical, but used least often) until I could get a replacement.
Vzproject
37
Lalor park
Vz Acclaim sedan 05
So did anyone figure out the cause for this or the solution or should I just replace and keep replacing? Tyia
Amyk
Sunshine Coast
VZ 05 Ute
Been having problems with my VZ starting intermittently, bought a brand new key, and was checking some other things and just noticed my Engine control relay looks a bit burnt on top also. Would like to know more about this too...
Fu Manchu
WA.
For those wondering...
Amyk
Sunshine Coast
VZ 05 Ute
Bought a new Holden relay but still is getting really hot even after a short running time...looks like I'll have to get it looked at...
