robfish
- Apr 6, 2014
- 4
- 0
- 1
- Location
- Scenic Rim
- 2007 SVZ Wagon
Hi Guys,
My VZ has started cutting out. It totally losses power, incl radio, dash, lights ect, then comes back on. It can start to do this when switching hi beam to normal beam, but also just randomly too.
I have checked battery terminals, ran a fault code check - just came up service due soon, abs fault (had just changed front brakes, but they seem to be working fine), but had started cutting out before I changed the brakes.
The car starts fine, but after a short drive up the road for 1 min, started to cut out.
When it first did this, I sprayed battery terminals with wd40, then next day was fine with no issues at all, but day after cut out only once. Then yesterday after checking all brakes etc, cleaning and re-attaching battery terminals, cut out after 1 min of driving 5-6 times in a row.
Diagnostic check - switch volts 5v , battery 12v. After starting car battery then 14v
Was thinking might be the Crank Angle Sensor?, and suggestions.
Thanks in Advance
Thanks in Advance
