tHe_sTiG
- Jan 28, 2010
- 190
- 2
- 0
- Location
- Saudi Arabia
- VZ Executive
I've got a VZ Commodore Executive Alloytec V6. So a couple of days ago I started the car and was greeted with the engine misfiring. At idle, the engine splutters and coughs, struggles when revving it, but everything's fine once up to 2000 rpm and above.
Dad's WM Caprice had a similar problem not too long ago, solved by switching out the ignition coil... so I suspected I had a similar problem.
Took it to our local GM dealer. They got back to us saying one of the cylinders failed the compression test, and the engine needs a rebuild. Quoted $7200
Something doesn't sound right... the car is clocked at 228,000 km; full service history, never skipped an oil change and never abused... I told them to check the ignition coil, they said they'll get back to me tomorrow.
Could you guys please chip in your thoughts? I'd be surprised an engine fail at fairly average km's and with good care. Would there be anything else causing the engine to misfire? Or am I due for a rebuild?
Thanks
Thanks
