SO I got myself a VZ Thunder
tittezzzvr
morisset nsw
VT v6 Berlina & 5LT VP International
So I finally got a new ute {But I HAD to sell a boat & a bike} dam wifes
Its a may 06 VZ v6 thunder ute
Anyway it had the old fan only on windscreen thing happening but that was just the hose of the inlet manifold
So I fixed that, topped up engine water, window washer, oil.
When I was burping the system the water in the filler began to bubble like it was boiling but the temp gauge said a quarter so I shut it down to let it settle & cool off.
after refilling the cooling system with water & re burping the system I shut it down & put engine covers back on.
THEN when I restarted it the check drive chain lights have come on.
Im REAL NEW to the VZ, Ive had many other commys but no squat about these suckers.
So all tips taken on board
SO, How the heck do I check the fault codes ????
" " reset the trip computer ????
How do I remove centre console ???
Where did you install you CB ???
Whats this button do ?? lol
Any links to posts would be good.
diysv6
SEQ
VF S1 SV6 STORM A6: VZ S1 SV6 A5
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
wives just don't understand!!,
but the guide covers most things, just go through it
check for codes, first step, could be just as simple as a cap,
tittezzzvr
morisset nsw
Just because I had 2 cars, 2 boats & a bike. IVE got TO MANY TOYS, Wash ya mouth out.
Uncalled for I say.
Thanks for the tips guys
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
there's 7 cars, 2 boats and a bike here, so I understand, you can never have too many toys, nice looking ute too,
whoever has the most toys wins they say!!!
Nate_L98
Lower Blue Mountains
VZ SS 6.0 Thunder Ute
How is the accelerator pedal in your Thunder? I f@cking hate mine, it's like pushing a heavy duty clutch
Gaiter
VZ SS Thunder
Mine is fine.. Mines got an after market clutch (unsure of brand - previous owner did it) and my accelerator feels nothing like the clutch. Its responsive and makes loud noises...
tittezzzvr
morisset nsw
Pedal is sweet as, works with 1 toe.
So any tips on TECH 2 or laptop hook up to this thing ?? 6 cyl auto if that helps
Nate_L98
Really? Well that's annoying, I bought a new one from Holden & the f@cker is just as stiff?
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
look up/google OBD11 or tech2 for vz and guys have all sorts off apps to use with, laptop, android phones, and apple gear as well, so if you are a bit of a technophobe you should be right, I just went out and bought an OBD11 To help me out if needed, VE, VZ, CRUZE, 2x ASTRA'S, ETC
