petern64
- May 18, 2012
- 288
- 20
- 18
- Age
- 60
- Location
- Branxton NSW
- vz ss 6lt , 2017 Mustang GT , 2021 BT50 SP
does any one know if the ECU in a VZ 6L will support an LS3 crate motor ??
ok , my VZ SS 2006 has an L76
Is that what the plate under the bonnet says? I have an 06 SS Thunder and it has the L98 6L, which I believe is similar to the LS2, but is not an LS2.
The L76/98 are all similar to the LS2 being all called Gen4 but the LS2 is different using LS1 style heads and reluctor wheel.
The L76/98 in the VZ is same as used in the VE except for the sump shape.
The difference between the L76 and L98 is the L76 has AFSM lifters fitted Like in VE but not activated in the VZ and the L98 uses normal lifters like the LS3.
L98's were only in the 06- utes. Sedans got the L76 for whatever reason.
