Drivers seat replaced now srs and airbag fault error
M.morgz
Hervey Bay
Vz crewman
Replaced the drivers seat in my vz crewman the other day with seats from a VT. I've noticed the old seat only had two electric prongs and where this one has 3.. At the moment it's connected so the seat moves at least but obviously I have a lose connection now, how do I rectify this?
Also since changing seat and charging battery as battery was flat I now get a SRS and airbag fault error.
I admit I'm pretty clueless with all this so any advice and guidance would be much appreciated.
It's my understanding I can't roadworthy the car with these errors? Was only roadworthied 3 months ago and due to being out of town didn't register now roadworthy has expired so was fixing the seat as the side trim snapped on the old one and seat was collapsed, before getting roadworthy again and now I have this issue. Frustrating to say the least.
kiwicon
NZ
VS V8 Manual
You will probably find it is the " old seat only had two electric prongs and where this one has 3" is your airbag light issue..
M.morgz
Hervey Bay
Vz crewman
Yeah I figured that much but can I splice the wiring or is it basically the seat isn't compatible with my car?
XUV
HSV XUV & Raised Cross 8 Trayback
yes, and you won't have rear passenger airbags ,which are in the front seat, door side.
It threw the code because airbags have a capacitor which stores enuff power to set off the airbags,
you should have disconnected the battery, waited 15 mins for the capacitor to drain, then do the seat thing,
but with the non standard seat it still would've thrown a code, which you won't be able to remove as it can't find the airbag ,
Code removal is a tech 2 job.
You could try and track down an EL46841 .......
jeepyrocks
BMW 535D, VR V6 Ute
They aint rear passenger airbags, they are front passenger side airbags- built into seat, and not available until VT series 2 as an option.
OP, check your VZ seat for an SRS airbag tag- if it has this then you need to get an equivalent seat as I doubt your VT seat has it. Roadworthy will fail without this corrected.
M.morgz
Hervey Bay
Vz crewman
Can't see an airbag tag anywhere on old seat.
The fact the battery was flat as a tack I didn't think to disconnect it when changing the seats :/
danoz vt vz
46
casino
vt 2000 wagon ve omega sportswagon
So can i take the plug from the vt and splice it onto the vz seats.And there seems to be one orange loom with no where to go.2006 svz seats into a 2000 vt wagon.Why cant the whole seat rail be changed onto the vz seat from the vt.If this can be done info on how would be gr8.thanks in advance.anybody help.
Fu Manchu
WA.
Why not just swap the covers and foams over. The rest is just steel.
Even swap the seat back to the original base and then swap the base foam and cover onto the original base.
An easy straight forward job that will leave all the factory functions as they were without stuffing about with wires and harnesses.
danoz vt vz
46
casino
Not being lazy but that sounds like a shitfight.Is there a link on how to do this im worried i will stuff the leather seats up.sounds good with help
I just havnt seen it done.I would do this if i knew what i was doing.Any help is good help thx.
Fu Manchu
WA.
There are sharp edges so where some gloves.
YouTube shows lots of videos on doing this. Not specifically to Commodores but all seats are manufactured using similar techniques.
It’s all clips. The foams sit over the frame. The covers are stretched over the foams and clipped to the metal frame.
Handy tip before reinstalling the cover. Fix the foam.
This will give an idea.
