Smiddie
I just did the timing chain cover on my car as it started to leak (Apparently a common problem with these engines.)
I have put it all back together roughly, and it started fine, turned it off and started putting everything down properly.
I broke the PCV pipe that goes from the air intake manifold to the rocket cover.
It started with out it. I then went and replaced it and now it wont start. I take it back off and it still wont start.
Each time i started it, it was for a few seconds no more, and it started no problem whatsoever, i started it twice.
Now that everything is on properly it wont start at all.
Have i killed the engine by started it with out the PVC pipe? I believe it somes type of air vacuum thing for the air intake manifold.
The first time i started it was when i put the pullies and belt on. It had some water but not alot, it also had about 4 litres of oil but not enough to fill it.
Again both times was for 2 secs only and quickly turned it off. I did it the first time just to make sure the pullies were all good and the belt was good. Im abit impatient like that lol.
