shueardm
Since I spent some time lately browsing forums I have now got "timing chain paranoia" . The condition is very real, I am all of a sudden petrified of my engine producing the findings some others have had to deal with. I can not afford $2500 if this were to happen to me. So I am wondering if it is a condition that I can cure with this post.
I have a VZ SV6 built April 05, engine number ( H051020560), 118000 kms, serviced on time, current oil Nulon 5w-30. Owned the car since 60000 kms and no apparent issues since we've owned it.
There are numerous threads on timing chains. This is not a thread on cost or how to replace timing chains on a VZ. I'd like to keep this very specific.
1) What engines are likely affected
2) How can it best be prevented if at all
Starting with 1) What engines are likely affected
I read some important notes on another forum that reads
Important Note:
This condition, in isolated cases, only affects the
7.7 mm pitch timing chain installed in engines
built after the following engine numbers:
H053340001 VZ@VE, VE, WL, WM
H051530001 CG
H051580001 RA
The 9.525 mm pitch timing chain installed in
earlier HFV6 engines is not affected.
Most importantly, are there any owners with engines outside this range that also had to replace timing chains?
Is it likely that every motor falling after this range will be affected ?
Does anyone know at which month/year these 7.7mm chains were installed. Is there any way for me to know ( other than motor serial number) what spec chain is installed in my motor?
If I happen to have a motor with a 7.7mm chain, considering it has done 118000 kms, what are the chances it will surface soon.
Is driving habits a major reason , what about oil. What can I do to minimize the risk
Important Note:
H051530001 CG
H051580001 RA
