shueardm
I replaced spark plugs today and the motor is running well. However the air conditioning is only coming from the demister. I searched and seems to be a vaccuum hoose is probably not on the right location, I cant recall where it was connected when I knocked it off, so I put it back the only place I could see it would fit and I have high doubt it is correct, it aint getting any air from the place I put it. The image might explain more. The tube with the white thing on it, where does this attach? I put it on the metal pin there and it is clearly wrong. I just can't see anywhere else it might go...
