TAHAIC
- Apr 23, 2016
- 5
- 0
- 1
- Location
- Brisbane
- VZ Commodore LE0 Alloytech 175kW
Hi, I need help from the experts out there. About a month ago I pulled the timer cover off due to an oil leak near the alternator, I replaced the water pump, thermostat housing complete and front water pipe seals while I was at it. Also replaced rocker cover gaskets and full set of injectors, spark plugs and even lower and upper inlet gaskets. It was running perfect - better than ever for about 3 weeks and then as I was driving to the petrol station (fuel was low but didn't run out) it started running really rough. I though I ran out of fuel it was so bad but I didn't and I fuel in it and it was still running rough. It's really bad like its misfiring on 1 or 2 cylinders buts its not misfiring - its so bad I cant drive it, it will idle but really rough and when I drive it sill really rough and no power at all. I have a OBDII USB connector and some basic software on my laptop to check and clear errors and it has no error codes logged or pending. I pulled the plenum of this morning thinking that it may be sucking air - the gaskets did look a little doggy despite only being new so I put the old gaskets back on but its made no difference. I can't imagine that the lower inlet gasket is the problem since its new but I guess it could be.
I disconnected the MAF plug and it made no difference in idle which was a little interesting. I checked MAF values with OBDII and it was responding to accelerator indicating to me that the MAF was working.
Has anyone got any ideas or had this type problem before with this motor LE0 175kW? I'm at a loss as to what it could be and would really appreciate some help.
Sorry if its been posted before but I searched and could only find posts where people had errors pointing to coil packs, spark plugs and such which I don't have.
