Radiator leak?
ThunderVZ0410
Holden Ute Thunder S
So I've just noticed some coolant on the side of my radiator, this hasn't always been there and has only appeared recently as I changed the coolant no long ago.
Does this indicate my radiator is on its way out and needs to be replaced?
Benboy
Hill River, SA
2007 SVZ Wagon
NO not necessarily. Some may have simply been spilled when re-filling. Suggest you go to an Automotive Cooling Specialist and get them to pressure test the system for you. Only really way to identify leakage problems unless you happen to find a spot that coolant is just pouring out. Good luck.
Wats_in_a_name
47
Carnegie Vic
VZ Executive
Have you seen any spills or stains on the ground beneath your car? If not it may simply be a spillage when refilling as Benboy said.
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
clean off with hose and check twice a day for a couple of days to make sure (cheaper option), or as above
ThunderVZ0410
I'll give it a clean tomorrow but I don't think it's from spillag, am I able to pick up a radiator bleed screw from anywhere aswell? Mine has broken in half..
