Engine replacement
gungazza
67
west suburbs
executive vt 5.0lt VZ CREWMAN
arnt thay the same 3.6 lt
Revhigh
Dandenong South
Holden VF Maloo
Call Holden, they will confirm, will have to replace the BCM, ECU and lots of other parts. Not an easy job.
Pelican Waters
VZ SV6
(After doing more research) I think I need a 05 model ly7 motor as in January 06 things got changed ie. Timing chain and some sensors went from analog to digital so the ecu needed a upgrade to match the engine
Do you know if you can still buy a crate engine for this model?
I'm learning towards a complete engine rebuild the whole box and dice
gungazza
67
west suburbs
there one on gumtree vz 3.6lt burwood nsw ph 040422085 $1000
gungazza
67
west suburbs
bit far from you but one at burwood nsw $1000 ph 040422085 gumtree
