Drewmans Crewman
- May 26, 2016
- 2
- 0
- 0
- Location
- Canberra
- VZ Crewman TrayBack 3.6
Hi Guys
I have been reading all about Rough Idle issues with the VZ Alloytech 3.6 V6 and thought I would put solutions in one spot for Newbies like me.
I recently bought a Crewman to fix up from Newcastle and knew there would be some issues but am surprised at some of them in that they seem to be Common VZ and Holden issues. These issues have been around forever obviously but there doesn't seem to be definitive solutions and I thought that I would make a list of the ones I have found and tried and will try when i get a chance.
The Rough Idle issue seems to be very common and solutions offered by other forum users are
1. New Plugs. (Done, no good)
2. New Coils. (Done, no good)
3. New 02 Sensors. (next payday)
4. New ECU either new or second hand but either way will need reprogramming or Holden to do it approx $900 - $1200.
5. Take negative cable off battery to reset ECU Wait 5 minutes and reconnect battery then rev at 2500-3000 rpm for 5 mins and then drive for half an hour. (Done no good)
6. Disconnect battery turn headlights and turn ignition on to drain residual power and repeat step 5.(Done no good)
7. Disconnect battery and take Stereo out as stereo keeps memory settings for ECU. (will try this one when I get the stereo removal tool)
8. Take fuel pump fuse out and start car till it dies and repeat attempt to start three or four times to make sure all fuel is removed from engine. (Done no good)
9. Use higher octane fuel or at least not E10. (Will do for new tank)
10. Don't do short trips too often as the car thinks it is normal to drive with cold engine etc.
11. Put in a Hotter thermostat. (will do anyway as is usually first thing I do to new car)
12. Low Voltage problem with alternator checked and producing around 14v.
13. Fuel Injectors. (will get checked before ecu replacement)
As the vehicle has done 218k kms Im happy to replace lots of things but I don't want to pay for a new ECU when it might be a simple fix and recur after replacing the ECU because the ECU wasn't the cause just a symptom.
Instrument Cluster needles failing is another issue i have looked at and I have decided to send it off for repair in Perth for $150 plus postage of $28. I have heard of Holden charging some friends of mine $1800 to fix the issue and then have it go again 7 months later. They sold the car and wont buy Holden again which is probably fair enough. This Crewman is my third Holden and certainly wont be going back to Holden again as I have had Issues with all three. Out of the 35 cars i have owned (my wife's, my kids and mine) in 28 years of driving the three Holdens would have to be the worst I have owned. Even my 2008 VW Jetta with DSG is better.
Anyway if you have had good conclusion to the same issue please post a reply or note,
I'm not after what it might be as it will just clutter the thread as with previous threads I have found on here.
