routier1642
- Feb 19, 2014
- 320
- 3
- 18
- Age
- 64
- Location
- Australia
- 2005 Adventra LX6
SUMMARY: Can I reduce body roll by doubling the front sway bar?
Since I raised the suspension on my VZ Adventra LX6, using Kings Springs, I have had one problem: in a tight corner, the outer front wheel dips down really noticeably. This would be body roll, except that the rear doesn't dip as much, possibly due to the stiffer rear setup with the auto-levelling suspension.
If it goes down far enough, the ESP (stability program) thinks I'm about the skid, kicks in and brakes the front outer wheel. At first I thought this was OK - the ESP is preventing me skidding. But I tested it on the same corners at the same speed, same degree of dip, ESP turned OFF, and there's no skid, nothing like it, even if I go a little faster. So the ESP is going off prematurely. It's not dangerous; if anything, the opposite; but it is annoying.
I came up with 2 solutions:
1) change the sensitivity of the ESP by moving the yaw sensor backwards; this will decrease front yaw readings and make the ESP go off less often. The disadvantage is that the real effects are really unknown, and would be until I'm in a situation where I need the ESP!
2) decrease the amount of body roll by increasing the effectiveness of the sway bar. I've read articles on how to shorten it by drilling new mounting holes further from the end of the bar, but I'm not sure the VZ bar will accommodate this.
Then I read this article AutoSpeed - Sway Bar Shenanigans
The author clamps a SECOND sway bar to the first, increasing anti-sway effectiveness if not 100%, then by at least some amount.
So my questions are:
1) Has anyone else experienced this problem?
2) Has anyone else tried doubling or altering an Adventra sway bar?
3) Opinions?
3) Opinions?
