dcrou7
So I was driving my vz alloytec and the temp started rising, overheating warning came on so I started looking for a place to pull over then check powertrain came on, it sputtered a little bit, I pulled over immediately, let it cool down, checked coolant and was half empty, filled up with GM coolant, turned ignition on and system check ok so started car ran smoothly as ever and seconds after starting check powertrain came on again. Car is running smoothly no loss of power and temps are low, everything seems fine except check powertrain. I haven't taken to machenic YET will do on my next day off. Anyone know what could be wrong? Is it safe to drive? I need it for work. Any help is appreciated thanks
