cheers, yes I have removed them before from the radiator cover etc using a screwdriver to lift up first, just whoever had before really killed them .
I am kind of putting this off now lol.
I may just listen to spofity streaming
Now I'm putting this job off as well........again.
My aerial is bent to buggery again !
Last time I tried just the 'Rope and Post' which had 3 of us working on it and def did NOT fit.
Then I tried a few full aftermarket units which were supposed to plug straight in, and DIDN'T. (Cutting wires and bending bits is NOT a direct replacement).
So now I'm really not looking to go through the whole process again !!!
(It's bent at a decent angle to match the A-pillar actually so if I stick a load of Epoxy in there and glue the aerial to the Bezel surround then I just have to buy a surround in case I want to fix it better later. What a lazy B*stard I am !)
If anyone has bought a unit that IS actually plug and play please let us know, thanks.
OP keep us posted. (Who will put it off for the longest time
. Mine still actually works to receive signal and I usually listen to my own USB input anyway. )
Cut them off with some pliers. Remove the panel. You can buy the replacement scrivets at Supercrap or Repco etc. in those packs that hang from a wobbly rotating tower.
Hey good tip , thanks.
