As you are probably aware the Holden Adventra has unique Rear Cargo Side Windows to the Commodore Station wagon.
The Adventra has a Rear Cargo Side Window panel painted in the body colour of the car.
VT - VZ Station Wagon Rear Cargo Window
https://photos.app.goo.gl/1lxIKppQdJKPhkco2
VY - VZ Adventra Rear Cargo Window
https://photos.app.goo.gl/d3q0NYozhZoBpMAh2
I recently "lost" the panel from my Adventra and had to purchase a new one.
Holden still had them but they were unpainted, and required you to purchase the CrossTrac chrome badge. Together this would be over $100 un painted.
On the 2nd hand market I was able to only find the entire rear cargo side window assembly which included the panel.
So I purchased a second hand window assembly in my body colour Heron White.
I could have removed the cars internal trim around the rear side window and removed / replaced the whole window (held in place by a series of screws) but I was really only keen on replacing the small panel.
The top of the panel is held on by 2 small clips and has 2 locating pegs.
Once unclipped, I had to slide a steel ruler in between the panel and the window assembly to break away the glue holding the panel on.
To my surprise there was also a Velcro patch holding the panel on.
The bottom of the panel just sits in two locating recesses.
After removing the panel I added some black window sealing glue to the back of the panel, then located the bottom of the panel, then clipped in the top of the panel. I then pushed on the panel to ensure the glue attached from the panel to the window assembly.
THE ENTIRE RIGHT SIDE REAR CARGO WINDOW FOR THE ADVENTRA - PART NUMBER 92115921
THE ENTIRE LEFT SIDE REAR CARGO WINDOW FOR THE ADVENTRA - PART NUMBER 92115920
THE RIGHT REAR CARGO WINDOW PANEL UNPAINTED FOR THE ADVENTRA = APPLIQUE-Q/WDO RR - PART NUMBER 92187480
THE RIGHT REAR CARGO WINDOW PANEL UNPAINTED FOR THE ADVENTRA = APPLIQUE-Q/WDO LR - PART NUMBER ########
THE CROSSTRAC PLATE - PLATE ASM-Q/WDO R/MLDG NA - PART NUMBER 92168682
