2006vznz
Hi guys
I purchased a s/h factory towbar with wiring loom. I fitted it no problem om to the car. I routed the wring loom into the boot area on the passenger side and plugged it to the corresponding plugs in there.
I read another page somewhere stating it should be on the drivers side - is the passenger side a no no? Also the wiring loom has a yellow wire with a plug that I can't figure out where it goes. Also a blue wire with no plug - just a copper end of the wire - where does that go?
On another issue seeing I am here, how do you turn off the 165000km service warning on the display?
Any help with these things is greatly appreciated
