VZ SS Parking Lights
Gaiter
VZ SS Thunder
One of my parking lights started blinking intermittently and eventually stopped working all together.
I replaced the globe in them, still no success. So I swapped the housing around between my two headlights and have determined it's the housing that is gone. I can't find any where to purchase a new / replacement. Half the battle is identifying them with a correct name. 'Parking light housing' or ????
Here are some pictures to show you the part, I went to a wreckers and due to them all having different headlight designs to mine, none had the same housing or even similar.
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
Not trying to be a smartarse, but have you tried holden yet.....:hiding:
Although they would probably want to sell you a whole headlight.
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
I would say they would be the same as Berlina and Calais lights. Might make it a bit easier to find.
Gaiter
VZ SS Thunder
Would try to sell me a whole headlight. Would charge me $250+ for said headlight. No, I haven't tried Holden. And a dealership is always my very very very last resort due to multiple bad experiences in the past
Gaiter
VZ SS Thunder
There are no commodore specific wreckers near me. And due to its small amount of model applications the wereckers I have been too didnt have it or the right headlight
Sandman
Challenge Accepted
Too many
Ebay maybe, the problem you will have is even wreckers will probably want to sell you the whole headlight as otherwise they're stuck without that one piece.
Fu Manchu
WA.
Noticed your parking light is an LED globe? You mentioned it didn't work when you replaced it.
If so, did you take it out and turn it round. Most LED globes will only work a certain way round. Turn it so the terminals on the end are the other way round.
Gaiter
VZ SS Thunder
Yea mate, tried both ways around. Tried non LED globes. No go
R
Risky
Guest
Gaiter,
Have you tried contacting The Commodore Shop in Cardiff Holden Commodore Spare Parts in Newcastle? I'm sure they'll have them. They'll even post to your address.
Wreckers tend to sell you whole headlight units but you might get lucky. Try using CRC Automotive Electronic Cleaner & see if that'll work.
