ForestVt
- May 16, 2009
- 24
- 6
- 3
- Location
- Brazil
- VZ exp 3.6 05
Another poor Brazilian - { as Fu Manchu says... :spot on: }
(but a toolbox, a scanner (CAN & ALDL), a GM service manual and a passion ...)
I have a 2005 Holden VZ. (in Brasil named "Omega CD")
I believe (not sure) that all of the Holden Commodore exported to Brazil are the same profile (for each year).
This I have - the features included:
3.6 L 190 kW (258 PS; 255 hp)
5-speed automatic transmission
6 disc in-dash CD player
Anti-lock braking system (ABS)
Auto headlights
Brake assist (BA)
Cruise control
Driver's and passenger's airbags
Dual zone electronic climate control
Electronic brake assist (EBA)
Electronic brakeforce distribution (EBD)
Electronic stability program (ESP)
Front and rear power windows
Independent rear suspension (IRS)
Limited slip differential (LSD)
Luxury suspension
Power antenna
Security system
Side impact airbags (SIAB)
Sports leather steering wheel
Rear park assist
Traction control system (TCS)
Trip computer
16x8 inch alloy wheels
When I bought, the odometer marked 30,000 km.
I even change the lubricating oil and filter every 5,000 Km. (synthetic 5W30)
In this month the odometer reached 240,000 km.
In this period of use, I already replacing some parts.
Tires, brake pads and brake discs, shock absorbers, bushes of the tensile bars, the entire cooling system included radiator, water pump, thermostat, and filler cap. Reviewing the charging system, I replaced the rectifier, the voltage regulator and brushes, and alternator bearings.
I have also replaced the battery, spark plugs and fuel pump and the oil pressure switch.
I almost forgot: The relay at BCM that "stuck" and melted the right taillight.
I made the replacement filter and transmission oil (5L40E) - included flush - to 75,000 kilometers and then to 200,000 km.
With all that, this car never let me down.
After a VT 1999, this is the best car I've ever had.
I also try to "listen" carefully, noise at the front of the engine.
The engine belt: :surprise:
I routinely inspect the engine belt.
I never replace the belt. Believe it or not, a new inspection that I performed this week, the belt comes in perfect condition !!!. No crack in the channels or apparent dryness. (I keep the spare in the trunk)
The cams drive chains: :whistling
I also never replace the cams drive chains.
For this reason, I worry about the consequences arising from any failure of these chains - (remains Holden originals).
Just one question:
I searched the forum but could not find: This engine (VZ Alloytec 190) has interference?
Thnks and Cheers
Auto headlights
Brake assist (BA)
Cruise control
Luxury suspension
Power antenna
Security system
Rear park assist
Trip computer
Just one question:
Thnks and Cheers
