Ive just recently picked up a second hand diff to replace the noisy one in my vz v6 one tonner. Just wondering if anybody could give me any tips or a walkthrough to replace it at home. Thanks
Chock front wheels
Raise the rear and put jack stands under chassis rails (in front of the front spring eye)
Unbolt the tail shaft
Disconnect wheel speed sensors
Disconnect the brake line at the T piece that connects to the brake piping on the diff
Undo and remove the U bolts attaching the diff to the springs
Lift out the diff by sliding one side over the spring towards the centre of the vehicle and then slide the other side through the same way and drag it out from under the vehicle.
Fit new diff assembly in the same way as the old one was removed.
And replace the U bolts with new ones.
You will probably have to remove the rear section of the exhaust to have the room to manoeuvre the diff out over the springs.
