Driveshaft options.
coolngroovy
Mackay Qld
MY06 VZ Calais
Hi guys.
Have a manual VZ 6 commodore with a broken/sheared driveshaft.
It has sheared between the center bearing & the diff.
What options are available? Is the rear shaft common on all models?
TIA
Tonner Matt
Darwin
VZ 1 Tonner LS1 M6
Not sure about compatability between models.
Sourcing a replacement tail shaft from the wreckers would probably be the quickest option to keep yourself mobile.
coolngroovy
Mackay Qld
MY06 VZ Calais
I'm just trying to help out a kid who broke down out the front of my house on saturday night.
He has been quoted $600 to replace the rear shaft.
Sounds uber expensive for 2" of tube!
I realise the front shaft will be different sizes depending on which gearbox/trans is fitted, but the center bearing remains in the same spot so i'm hoping that the rear shafts are all the same size. Fingers crossed.
petern64
60
Branxton NSW
vz ss 6lt , 2017 Mustang GT , 2021 BT50 SP
give Ebay a crack , there should be something there for a couple of hundred bucks to the kid goin !
coolngroovy
Mackay Qld
MY06 VZ Calais
The kids picked up another complete driveshaft today.
It seems to be about 1/2" too long on the front shaft.
Will take it into a shop tomorrow & have the rear shafts swapped over.
Towcar
Auckland NZ
VX Berlina Wagon
The cost that he would have been quoted would include balancing, which will need to be done.
There are so many variations on the driveshaft and it is important to get the right one, also it is just as likely a second hand one will have a flogged bearing.
Pollushon
Boost gives me a bar....
VY SS
I got a complete reco driveshaft for $350 exchange from the Canberra arm of rare spares. I'd ring around.
