Results 1 to 17 of 17
Thread: VZ Binnacle Loom
    WILDVZ Guest
    Default VZ Binnacle Loom
    Hi Everyone,
    I am going to install some monaro binnacle guages into my SS shortly and I was wondering if anyone has made up a loom themselves and has any photos that they can post up? I am only curious as I am not sure if the end of the loom that goes into the instrument cluster has a plug or needs to be bare wires. If there is anyone who has installed these guages into and SS (as they don't have the loom already there) and they can help out it would be greatly appreciated.
    Thanking you in advance,
    Wildvz
    Marks-VY's Avatar
    Marks-VY is offline I love cars
    VT2 Berlina
    Apr 2005
    This was a pretty easy wiring job for me. My gauges were aftermarket and I had no loom or factory wiring. You amy need to test the gauges to determine what wires are what.
    I tapped into the mobile phone plug for the accessory live and earth. There is a spare plug under the centre console which I think is used for the ciggy lighter, I used that for the lights (using a test light I found a light circuit wire).
    The biggest job was running a wire from the binnacle to the front of the block for the oil sender (V6). I found the grommet for the main wiring loom had sufficient "give" to push a coathanger through from the INSIDE of the car, to which I had taped the wire. I ran it under the existing loom as much as possible to keep it clean. Easy!
    EvoVIIIJDM is offline Got Evo?
    Evo VIII JDM
    Nov 2005
    Sorry to hijack your thread a bit, but is it easy to install these binnacles into my SV6? There wouldnt be any wiring in there at the mo so it would need to go in?
    Quote Originally Posted by Skitz View Post
    Go ahead with the SS badges,you will reap the benefits.
    I have put SS badges and the kit on my VE Omega and when I go cruising and rev it past the girls.........well what can I say,they have drool running down their face.I chuck a U-turn and they say ''Nice car'' and I say ''It's an SS,jump in''.
    Marks-VY's Avatar
    VT2 Berlina
    Apr 2005
    Quote Originally Posted by highendrev
    If you splash out and buy it with all factory gauges and wiring then I expect it would be plug and play. If you want to save money like me then there is a little more fiddling but with a minimal amount of electronics understanding and a test light, you can't go too far wrong.
    Sensations Guest
    Not if ya know ppl that work for Holden
    But the guages are a waste of time IMO - Just Oil and Volts.
    VZ Storm ute M6
    Dec 2005
    Northern Sydney
    If anyone here looks on the LS1 forums site there is a LOT of discussion about the gauges. Apparenttly its not as easy or as cheap as it sounds.
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    the VZ binnacle set is run on serial data, they dont use the oil sender.
    Rob
    Evo VIII JDM
    Nov 2005
    ah ok, money not a prob, ill get holden to put them in. They are prob a waste of time, but they have a shitload of COOL factor
    Marks-VY's Avatar
    VT2 Berlina
    Apr 2005
    Quote Originally Posted by Doctor Bob
    Rob
    Sounds like I did the right thing buying cheap aftermarket gauges - and they are accurate (I replaced mechanical with electrical and they were spot on).
    Sensations Guest
    That is true
    VZ Adventra
    Dec 2005
    I have had VZ binnalce gauges installed in my Adventra and they are not plug and play. The patch loom is not available from Holden.
    NVU a division of Motorfield Pty Ltd in Thomastown (03 94661011)have a loom and a wiring diagram showing how its connected to the cluster loom, but NVU may not sell the loom by itself.
    There is also a wiring diagram on LS1 forum in one of the threads.
    Ross
    Evo VIII JDM
    Nov 2005
    Cheers for that info Ross.
    06 Thunder S2
    May 2006
    I thought i'd throw this in, cos i was down getting some work done on my thunder and asked them how much it'd be for those gauges. The responce was... it's bout 500 bucks, because they don't make aftermarket ones, and about another 500 to get them fitted.... so it'd need to be a Shiite load of cool factor for me to get them.
    They do look wikid tho...
    dufus is offline Donating Member
    rickshaw
    Jun 2006
  15. #15
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
  16. #16
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    this is convienent now, has anyone used these?
    HSV/VDO VY&VZ DASH KIT-BINNACLE,LOOM,GAUGES-BRAND NEW ! - eBay, Other Car Parts, Accessories, Car Parts, Accessories, Cars, Bikes, Boats. (end time 09-Jan-09 08:23:46 AEDST)
    any feedback for the quality of them? is the adapter kit they provide at an extra cost genuine holden or another? im thinking of getting one before track day, just incase.....
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
  17. #17
    VY SS UTE A4
    Jan 2009
    Vz aux gauges wiring diagram
    Attached Files Attached Files
  1. HSV Binnacle
    By Mr_Calais in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-10-2007, 05:53 PM
  2. Can I replace VN V8 loom with parts of VQ V6 loom?
    By holdenrules in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2007, 03:02 AM
  3. VZ into VY binnacle guages
    By calaiscruiser76 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-07-2006, 07:43 PM
  4. My binnacle installation, Thanks all!
    By Lumps of cheese in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-06-2006, 06:20 PM
