Results 1 to 8 of 8
Thread: Sv6 2005 Noisy Air Con
    RYE
    RYE is offline
    VZ SV6 2005
    Jul 2005
    Angry Sv6 2005 Noisy Air Con
    SV6 Has only done just over 15.000 and the air con is making a noise, only on hot days? the noisy comes in to play when in heavy traffic going through the gears, holden had told me the air cons do make a noise, "it's nomal" either they are deaf or i am going mad, none of my other holdens have had this noise
    Z Series ClubSport
    Aug 2005
    Can you describe the noise? Like is it a whine or a whoosh kinda thing? Does it appear to be coming from the vents or elsewhere?
    EvoVIIIJDM is offline Got Evo?
    Evo VIII JDM
    Nov 2005
    Sounds Like Its Charged Or Sumfin Especially Thru 1st And Second,
    Quote Originally Posted by Skitz View Post
    Go ahead with the SS badges,you will reap the benefits.
    I have put SS badges and the kit on my VE Omega and when I go cruising and rev it past the girls.........well what can I say,they have drool running down their face.I chuck a U-turn and they say ''Nice car'' and I say ''It's an SS,jump in''.
    RYE
    RYE is offline
    VZ SV6 2005
    Jul 2005
    Question
    Quote Originally Posted by DavoTheGreat
    It's not coming from the vents, it sounds like it is at the back of the engine just behind the fire wall, holden have changed the compressor but the noise is still there? it got me beat??
    Chim Chim Guest
    I have got exactly the same issue with my 05 SV6 Auto. Holden has no idea what it is. I had a 02 Mini Cooper S that also did the same thing too, BMW took about 4 goes to fix it and in the end I can't remember what they did.
    Jason
    VZ SV6
    Jan 2006
    Do you mean the 'whining' noise that seems to get worse when the A/C is on?
    VE2 SS 6sp Manual
    Mar 2006
    Sth East Vic
    in my ute... im gona make note to holden about it too... think with the ventilation fan theres somthin a miss squeaky bush/bearing in the motor - located behind lower glove compartment... tried n tested cause frequency changes to fan speed and goes when fans off... anywas it sounds kinda like a mouse on a running wheel... most likely different to what u are experiancing?
    VZ SV6 manual
    Jul 2005
    Not sure if this is the same noise but mine had the (aluminium?) block that exits through the firewall that the aircon hoses attach to touching the firewall. Made a metallic sound at about 2000 rpm, particulary left hand turns. This is located in the firewall in front of the glovebox. Took bloody ages to find cause. Temporarily fixed by bending connecting block mounts upwards. Pressure in hoses causes same thing?
    It is impossible to make anything foolproof because fools are so ingenious
    2004 SV6 manual, quicksilver, LSD (now standard!?), parking sensors, 6 stacker, bluetooth car kit, 1600 kg tow, tinted windows, K&N filter, strut brace
  1. Noisy lifters..what does it mean?
    By Clacker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2006, 10:07 PM
  2. noisy lifters? maybe
    By sleepyvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2005, 11:58 AM
  3. Noisy Air Con
    By Zedlen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-08-2005, 01:56 AM
  4. motor noisy need help!!!
    By Darrell Long in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-06-2005, 11:06 AM
  5. trans noisy
    By vlcalais88 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-05-2005, 05:56 PM
