Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Gas On Alloytec 190
    CNULTR's Avatar
    CNULTR is offline SLEEP3r
    VY 25th Anniversary II
    Sep 2005
    Default Gas On Alloytec 190
    My father owns a 05 WL CAPRICE and bc the vehicle runz all day, he is thinking about installing a GAS system in it. What do use recommend shud he or shudnt he also will the Alloytec 190 stuff up?
    benzor's Avatar
    benzor is offline yawn :(
    SV6!
    Jan 2006
    Alloytec 190 doens't do gas, plain and simple, it can't be done.
    The 175 does however, it requires a complete different setup, from what I've heard there's another complete set of gas injectors + a completely new manifold fitted.
    Also when posting, please try to use english, having to read the thing 4 times before responding kind of sucks.
    Hibba is offline Fixing Your **** 24/7
    Toyota Cressida 2.5TWINturbo
    May 2005
    Currently the 175 is the only Alloytech avaible from factory with LPG, and its quite a unique setup at that to.
    As far as we know there isnt a plan to release a 190 on gas.
    As far as if it could be done aftermarket? In all seriousness i couldn't tell you and i dont think anyone else could. I don't even think its been atempted, but i guess it could be done. Hell people said you couldn't do a Gen3 on gas, yet i have seen it done.
    vy_storm's Avatar
    vy_storm is offline just another moderator...
    VE Calais V 6L
    May 2005
    the burbs of Adelaide
    Give it time, LPG demand is increasing so much at the moment because of petrol prices going up. When there are more Alloytecs on the market out of warranty I think you will see a few people trying to attempt it.
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    it has been done & it has also voided the customers engine warranty, the engine needs to be factory fitted with lpg & all the associated mods, if this is not done the cylinder heads WILL fail, no ifs, no buts.
    The conversion i saw was a POS & didnt start properly, idled like a hat full of busted ones.
    Cheers Rob
    CNULTR's Avatar
    Sep 2005
    2007 Black CDTi Astra 6sp manual
    Apr 2006
    Hi Guys,
    Been meaning to dig this old thread up for a while.
    Does anyone have any updates on gas converstions for VZ's??
    Petrol prices are sky-rocketing and I struggle to believe that Holden still hasn't released a conversion kit for the 172/175 and 190kw engines.
    As far as I know nobody is doing the conversions here in WA.
    Anymore new info muchly appreciated.
    cheers
    Tom/WA
    BLACKVZSV8's Avatar
    BLACKVZSV8 is offline 300 rwhp
    VZ SV8 M6
    Feb 2006
    As far as Im aware anything with a plastic intake manifold cant run on gas ie Gen3s alloytechs etc
    2005 VZ SV8 Black 6spd Leather tuned 300rwhp
    VE SSV Ignition
    Feb 2006
    Mandurah W.A.
    Quote Originally Posted by BLACKVZSV8
    the intake manifolds on the gen3 and the alloytecs are made from alluminum, or are u meaning the intake pipe? if you are then it is possible because the gas just flows through the intake pipe and into the engine.
    BLACKVZSV8's Avatar
    VZ SV8 M6
    Feb 2006
    The manifolds are composite plastic.
    Basically you cant run them on gas because the manifold cant cope if the engine backfires (which can happen on gas).
    To run them on gas you need to change the manifold.
    Scotty_Doesn't_Know is offline Don't Tell Scotty...
    Holden VE Calais
    Apr 2006
    Canberra, ACT
    Why are do so many people mis-understand LPG?
    The ONLY PROBLEM Holden (and any manufacturer) have is how to produce a good DUAL FUEL solution. i.e. an engine that runs on both LPG and Petrol. Most people don't want to be limited to ONLY LPG even thought it would be a better solution.
    Any well informed mechanic, mechanical engineer or LPG specialist will tell you a car that runs SOLELY on LPG with a proper and FULL engine modification will not only run smoother, cleaner and further, but it will also produce (or at least have the potential to produce) MORE power! LPG has a higher octane rating than Shell's Optimax Extreme (the only 100RON fuel on sale in Australia).
    If an engine is properly and very professionally FULLY converted to LPG and tuned specifically for it, it's a MUCH better solution than petrol. Problem is, not many people know this.
    Duel fuel is harder (for obvious reasons - well if they aren't obvious you should give up trying to understand) to do right.
    The MAIN reason petrol powered engines are more common if LPG has the potential to be better??? Well, LPG was an after thought, a bi-product. It is waste left over when refining petrol. LPG - Liquid Petroleum Gas. And there simply hasn't been as much development in using it because to refine and use it, you have to be refining and producing petrol...
    Something else people may not be aware of regarding the cost of LPG is that it is not currently subjected to the 38.14 cents per litre Federal Excise that petrol fuels are subject to. However in 2011, the whole system will change. The taxation system that will be implimented in 2011 on all fuels will be based on their "energy content". So THEORETICALLY this will make fuels with more "energy" and that are more environmentally friendly (such as LPG, Diesel and the higher octane fuels) could in fact end up being cheaper than regular unleaded. Most opinion however is that current fuel prices will remain the same (or similar) and this is simply going to be an excercise to bring LPG into line with them.
    NRMA has a good read: http://www.mynrma.com.au/carbuying_lpg.asp
    VE SSV Ignition
    Feb 2006
    Mandurah W.A.
    if the manifolds are made from plastic of any description it would melt from the high under bonnet temps so the manifold needs to be made from a metal to withstand the temps, there would be no need to change the manifold because the gas system can be fitted in before the throttle body, even on dedicated gas cars the manifold is the same as on a dedicated petrol car the only difference between both motors is one has injectors and the other doesnt, and the throttle body is different.
    BLACKVZSV8's Avatar
    VZ SV8 M6
    Feb 2006
    Quote Originally Posted by JanetSV6
    Do some research, ring holden, or even do a simple google search on LS1 and gas. The manifold IS PLASTIC !!!!!
    Please dont respond till you do some research on this as I have.
    Refer to www.ls1.com.au for more information and ring your local holden dealer.
    vz sv6
    Oct 2005
    Cool
    BLACKVZSV8
    Bit uncalled for PAL! It was you afterall that asked when SV8 had gone to 3.7 diff gears? This information was freely available if you had checked?
    Give the lady a go? She is asking reasonable questions and deserves a reasonable reponse!
    Do I make my point............
    Ian
  15. #15
    BLACKVZSV8's Avatar
    VZ SV8 M6
    Feb 2006
    Quote Originally Posted by west55
    BLACKVZSV8
    Ian
    What's uncalled for? Stating facts? Wake up.
    She got a reasonable response the first time and chose to ignore it. I then responded AGAIN with legitimate information.
    Point? What point you made a worthless post thats about it.
  16. #16
    Vz Clubsport ls2 A4
    May 2005
    Material Applications for Alloytec 3.6 engines.
    Block Material:
    Aluminium, precision sand-cast 319 with cast-in-place iron liners
    Cylinder Head Material:
    Aluminium, semi-permanent mould 319
    Intake Manifold: Upper: Aluminium, gravity die 319
    Lower: Aluminium, gravity die 319.
    NO plastic intake here on Alloytecs'
  17. #17
    Doctor Bob's Avatar
    May 2004
    Quote Originally Posted by twb1979
    Hi Guys,
    cheers
    Tom/WA
    Janet, the LS1 inlet manifold is composite plastic
    the alloytec is aluminium alloy
    Cheers Rob
  18. #18
    VE SSV Ignition
    Feb 2006
    Mandurah W.A.
    thanks for that doctor bob, i didnt clarify what i was meaning when i was speaking about the intake manifolds i was refering to the alloytech motor and not the ls1, should have made it more clear in the start, Cheers Janet
  19. #19
    BLACKVZSV8's Avatar
    VZ SV8 M6
    Feb 2006
    My bad I knew the 8 was plastic was sure the 6 was plastic as it looks and feels plastic.
  20. #20
    BWald Guest
    Default Gas on Alloytec 190
    Just searchin google and found www.lpgautogas.com.au which lists a complianced kit by Sprintgas P/L 03 9350-5500 to suit all VZ alloytecs. I havent contacted them but seems like they are in Vic. somewhere.
    Bruce
  21. #21
    BLACKVZSV8's Avatar
    VZ SV8 M6
    Feb 2006
    Come on Janet if i can admit when i was wrong Im sure you can too !!
  22. #22
    VE SSV Ignition
    Feb 2006
    Mandurah W.A.
    ah ok i guess im wrong on what i had put i was under the impression that the ls1 manifolds where also made from alluminium, i was also wrong about the manifolds on the ls1 melting at high temps but if there made from composite plastic there is a huge difference in tempreture withstanding points. my bad too so we both now stand corrected. Janet
  23. #23
    BLACKVZSV8's Avatar
    VZ SV8 M6
    Feb 2006
    I did state they were made of composite plastic in the beginning
    Yes we are both noobs who are now better educated
  24. #24
    VE SSV Ignition
    Feb 2006
    Mandurah W.A.
    Yes we are now both better educated. somehow missed the composite plastic bit in the start. my bad. allthough allready admitted. Hey were both from WA but u dont join our cruises. U got any reason for that. Be good to have someone new along.. maybe
  25. #25
    BLACKVZSV8's Avatar
    VZ SV8 M6
    Feb 2006
    I havent seen any local cruises posted yet, if I do Ill come say hi for sure.
  1. Alloytec into VT?
    By denizengt in forum V6 Development And Modification
    Last Post: 11-05-2006, 03:52 PM
  2. Alloytec KW
    By Baritji in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-03-2006, 06:13 PM
  3. Oil for my Alloytec??
    By Phreddy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-02-2006, 12:31 PM
  4. LPG Alloytec
    By old mans ute in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-10-2005, 07:25 PM
  5. Alloytec and Alloytec 190 Engine Specs and Details
    By Gobbles in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2005, 05:24 PM
