Results 1 to 3 of 3
Thread: Just fitted MCAI to my SS Thunder Ute
    vxexec350's Avatar
    vxexec350 is offline <--6ltr VZ SS Ute
    VZ SS Thunder/VX Exec LS1/VN Berlina 5.0
    Oct 2003
    Adelaide Northern Suburbs
    Default Just fitted MCAI to my SS Thunder Ute
    When I bought my SS Thunder I was amazed at the air induction it came with. It was even more restrictive than the VT/VX LS1 style as it has only got the pipe that goes under the radiator cover and no second hole . I went and bought a MCAI to see if it fits, if it didn't I only waste $9.45. Well it does, kind of fit. I had to modify it to go around the coolant dipstick tube. Also the air box is on a different angle so the 90mm holes don't line up, a piece of 90mm flexible tube will fix that.
    Verdict;
    Obviously as I don't have my own Dyno I can't substantiate claims of a power increase, however, it did make a difference, quite a good difference too. The car had a slight hesitation low in the rev range that was almost like a carb flooding...fixed. It accelerates more aggressively and the power feels more linear.
    Aurally it is a lot less ghey.
    Edit: I also did the second hole mod so THAT hole lines up LOL.
    The car is stock except for some badge engineering and SSLows. Overall the driving experience is
    Pete
    VZ SS 6.0 Thunder M6
    Apr 2006
    Talking
    Good stuff,
    l have been looking into CAI setup in my Thunder ute. Not too sure witch path to go down at this stage. Can you post some pics of your setup?
    vxexec350's Avatar
    Oct 2003
    Quote Originally Posted by bodella
    Good stuff,
    It looks stock
  1. MCAI Part Numbers and How-to
    By OLS108 in forum LSx Development and Modification
    Last Post: 08-11-2011, 10:08 PM
  2. Has anyone fitted a MCAI to VY2 clubby
    By mar-d-mac in forum General Discussion
    Last Post: 08-11-2007, 01:49 AM
  3. ripoff? mcai
    By commisme in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-12-2006, 06:52 PM
  4. My New Thunder SS Ute M6
    By Lemon in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-05-2006, 04:40 PM
  5. New Thunder S ute?
    By skarekrow in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-04-2006, 12:46 PM
