Results 1 to 16 of 16
Thread: Lower Grill Gaurd
    VZ SS Crewman
    Jun 2006
    Default Lower Grill Gaurd
    Do any of you guys know where i can can a lower grill gaurd for my ss other than ebay and how much should i expect to pay.
    Thanks boughto
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    wreckers, holden itself. if i remember correctly i dont think it was that much, less than $100
    Turismo Blue 2005 VZ Storm Panelvan
    May 2005
    yeah mate, i got one from a SV6, cost $35 for the genuine holden part.
    fitting, of course, is heaps more.
    08 VE SSV M6
    Dec 2005
    I went into my local Holden and wanted to order the same thing for my car and was told that they don't fit the ute. Surely the sedan and front bar are identical? I realise that I would have to get the brackets as well.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Andre's SS Guest
    They dont fit into the SS VZ ute properly- Had to silicon them in myself!!!
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Quote Originally Posted by SSZ Ute
    they are different. on the ute the back of thethe bar where the grill sits doesnt have the clips.
    as andre said, buy it and use silicone to glue it in. works just as well
    May 2005
    it looks perfect on mine. I was sure I was gunna break it so I just paid them to fit it. to fit it properly you've gotta completely remove the bar so it took a couple of hours and hit me up about $100 just for fitting. But $130ish later and it looks...normal.
    In my opinion they look pretty stupid without the grill in there!
    From what I can tell the Front bar for a S-pack, Storm & SS Ute & Crewman are all the same as the SV6. They just dont come with the clips. you've gotta buy the clips as well for the grill or yea it wont fit properly.
    yeah sillicone will probably do the trick, but to do it properly you've gotta remove the bar, and good luck doing that without breaking or scratching anything unless you REALLY know what your doing.
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    removing the front bar takes 5 minutes with 2 people. it is a matter of 7 screws and a bit of pulling.
    i should really get off my arse and take some pictures of how to take it off
    infact, i might do that this arvo and post it as a sticky thread
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Andre's SS Guest
    Troy YA recon if i bought the clips for a VZ SS sedan they will fit onto
    my ute? Never thought of doing that
    VE Calais V & VZ Storm Ute
    Jan 2005
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Jan 2005
    Thanks. I will give it a try after reading your post on how to remove the front bar.
  15. #15
    VZ SS THUNDER
    Apr 2006
    Don't buy them off ebay... The cheapest I've seen is $49 or something. I picked mine up the other day for $25 from Holden...
    It's a piece of piss to put in... Good luck!
  16. #16
    vxexec350's Avatar
    vxexec350 is offline <--6ltr VZ SS Ute
    VZ SS Thunder/VX Exec LS1/VN Berlina 5.0
    Oct 2003
    Adelaide Northern Suburbs
    Quote Originally Posted by VZGEN4
    That is exactly how easy it is. I also used silicone glue. You can manouver the grill through the opening without removing bumper. I used an ockie strap and a stick (with rag protecting paint) to hold it in place while the glue set.
  1. How much lower?
    By ::Team420:: in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-11-2006, 09:59 PM
  2. SV s9 LE Front Gaurd Sticker
    By VN-SV-89-LE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-09-2006, 03:00 PM
  3. vq driver side gaurd and door please
    By vrjay in forum Swap / Wanted to Buy / Trade
    Last Post: 03-05-2006, 12:42 AM
  4. VX Left Front gaurd removal
    By MikeVXSS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-04-2006, 01:02 PM
  5. lower the cam
    By Shivaga in forum General
    Last Post: 15-11-2005, 12:31 AM
