Results 1 to 15 of 15
Thread: What is the VZ SS rev limit?
    Nov 2005
    Default What is the VZ SS rev limit?
    Hi,
    Just wondering what the VZ SS rev limiter is set at? ive had it to 6500rpm and it didn cut out. Im sure people here have hit it a few times.
    Thanks
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    I've got an auto VY SS. A couple of times I've held it in 1st and "accidently" lost traction in the wet and over-revved it.
    It didn't hit a rev-limiter as such but changed into 2nd for me - even though the shifter was still in 1st. Ouch - I won't be doing that too often!
    I didn't see the tacho too well since I was too busy concentrating on the road, but it was at around 6000 rpm.
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    MY45 Guest
    VE R8 LS3, VYSS Ute 10.0@146MPH & VYSSTT 525rwkw
    Jun 2005
    SA
    the rev limiter is set at 6250rpm, did the car really hit 6500 or was the needle shooting past....(this is also common)
    Sep 2005
    Quote Originally Posted by enhancedss View Post
    the rev limiter is set at 6250rpm...
    Is that something that you change when you do an edit tune?
    Johnsy's Avatar
    Johnsy is offline ★★★★★
    HSV R8 LS3
    Oct 2005
    C/Town
    Its ok to put it into first and put your foot down the car changes around the 6200rpm mark and then goes into second automatically, if you keep your foot flat it will hit the rev limiter in 2nd gear.. You just have to be carefull when slowing down as it will go back to first and you will get compression lock up (tyres will screach).
    You can't hurt your car by giving it all you can ( in a straight line ) that's why there is a rev limiter
    Z Series ClubSport
    Aug 2005
    Quote Originally Posted by davey g-force View Post
    Yes it can be changed in a tune... but unless you were going to do some serious work to the motor you wouldn't change it. I'm not sure what a mechanically stock LS1 can rev to without damaging it but I doubt they'd pull anything like 7000rpm safely.
    Jun 2005
    SA
    1 of many things u adjust, but u only change this if the vehicle keeps producing power above this rpm......
    a few other things that are adjusted as well. eg me personally i like taking away the auto upshift, when holding the shifter in first.
    turning on cooling fans earlier. and other things like change the time frame and tables for warning systems, eg running hot, or oil pressure dropping.....etc.
    But all in all a very noticeable difference in a car, once tuned.......that will leave u asking yourself, why did i wait so long.
    Sep 2005
    Thanks Davo & Brad.
    Quote Originally Posted by SSZ-57L View Post
    ...You just have to be carefull when slowing down as it will go back to first and you will get compression lock up (tyres will screach)...
    LOL! That's exactly what happened to me - AND I nearly went through the windscreen!
    VZSV8M6
    Aug 2006
    I have my rev limiter set at 6400rpm with my edit, only internal mod is the valve springs cause mine were floating around at about 5500rpm.
    I have Pacemaker 4>1s, high flow cats, difillipo twin 2 1/2in cat back it revs very nicely to the limiter but 6400 is about its safe limit. Oh yea its also a M6 LS1. The edit is the best mod I've done and worth every dollar, there are so many things done in the edit all of which add to the drivability of the car, great throttle response improved torque curve and obviously heaps more power even better fuel economy(improvement of around 1.5l/100 less fuel usage). Power went from 200rwkw stock to 220rwkw with a MAF tune no mods at all then to 240rwkw with the exhaust and enclosed K&N pod CAI and tune touch up.
    Go see a tuner you will not regret it, if money allows I would advise a custom tune over a mail order if you are running a few mods to get the most out of these mods especially if you are considering extractors and cats.
    Johnsy's Avatar
    HSV R8 LS3
    Oct 2005
    C/Town
    Thanks Davo & Brad.
    Yep... But get this davey.. my VZ wagon stays in first when i punch it and hits the rev limiter, it dosent change automaticaly into second like our ss's..
    vxexec350's Avatar
    vxexec350 is offline <--6ltr VZ SS Ute
    VZ SS Thunder/VX Exec LS1/VN Berlina 5.0
    Oct 2003
    Adelaide Northern Suburbs
    Johnsy's Avatar
    HSV R8 LS3
    Oct 2005
    C/Town
    Press mode and set at the same time, keep them held then start your car.
    Within the stats you will now see, keep pressing mode till you get to the electronic rev limiter. Put your car in first put your foot down and see exactly when it changes into 2nd..
  15. #15
    Johnsy's Avatar
    HSV R8 LS3
    Oct 2005
    C/Town
    Quote Originally Posted by MY45 View Post
    ill check for u tomoz
    2 months later..... lol
  1. 253 rev limit
    By Nobody Actually in forum V8 Development and Modification
    Last Post: 09-11-2008, 01:49 PM
  2. $12K limit
    By nEb. in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2007, 08:33 PM
  3. Rev Limit
    By Stewart1000 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-01-2006, 08:20 AM
  4. limit??
    By Tekka in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-10-2005, 10:34 PM
  5. Lowered limit??
    By Robbo74 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2004, 09:48 PM
