The front doors have a 61/2" mid driver, which is actually in a 6" DIN sized spacer. Most major brands will fit in, back doors are same i believe. I have Infinity perfect 6's in my SV6, a bit of a squeeze but worth it, have also put calais grilles in back so could put the infinity 6x9's in rear trays and have 2 x 10" infinity perfects in custom box out back. All running off facotry head and JBL amps. Does not sound too bad, factory heads pre-amp lets things down a bit as it seems to have a subsonic filter built in even if you turn all the compression off.
When changing the tweeters (std is 1" polycone with rear m4 screw) watch out for one little screw which you access through the air vent supply from the dash to the door, broke my first ones on my old vt. The crossover is just basic in line capacitor by the tweets and nothing for the mids, i would recommend putting your own crossover and new wiring to both tweets and mid's unless you plan to use factory head. In that case may be best to split the components out of your crossovers and place by the drivers as they are wired in parallel as standard.
And yes i did used to work for the JBL & infinity distributors incase anyone was wondering, so if anyone needs any audio advice, i have tried almost everything in VS, VT, VTII, VX & VZ...
