Hi
We have just bought a VZ second hand. It appears that the clips securing the radio in have been damaged at some stage and will not release with the tool.
Can I release the head unit from the rear?
Hey Ozjock.
Hmmmm, it's not easy - from the left side (after you remove the glovebox and pull a couple of screws) you can get some limited access to the back of the thing. It's not easy though!
A suggestion - use some coat hanger wire bent in a wide "U" shape (86mm across) and on the very tips of the prongs make a nice sharp little bend. Trim that off with a hacksaw/file (or a Dremel) to leave only 1 or 2 mm of "bent bit" and try those in the extraction holes. With the bent ends, you may get enough purchase to pull the unit out.
(Hmmm - these bodgey blokes who bend these clips.... I've come across numerous of these - with the proper tool you can get the unit out in a few seconds - UNLESS some nob-head nas screwed up the lock clips, that is....)
Cheerz, all the best.
New look ASR Website online now!!
www.asr-audio.com.au
Interior lighting and audio specialties
for VT/VX & VY/VZ Commodore / Monaro
NOW VE DASH LIGHTING CONVERSIONS!!
PLUS TECH2 DIAGNOSTIC SERVICES
JBL Car Audio dealer
