+ Reply to Thread
Results 1 to 13 of 13
Thread: New ECU software 172 or 175?
    VZ 175 Alloytech
    Oct 2006
    Question New ECU software 172 or 175?
    Hi.
    My VZ exec wagon has the problem with the after market H/U and the dissapearing dash menu's. Coupled with the notorious fuel gauge, and off to my local dealer I went. I explained the problem(s) (paint peeling from door handles too..) and service adviser wants the car to reflash dash AND ECU to fix the dash and fuel gauge.
    My question here is being a 7/2005 model will I end up with the latest "175" software, ie. Euro 3 compliant - which I believe is a "172" kw tune?
    Or will my car's tune not alter?
    Curious...
    Thanks
    Laurie.
    PS. Current Software Version is: 000.027.000
    VU SS
    Feb 2006
    The Shire
    not sure how much power you will get, but you deffently wont notice the difference in 3 kilowatts..
    but is there a difference in torque between the two???
    Turismo Sv6 with leather
    Aug 2006
    I may be wrong but doesnt the software upgrade ur refering to affect the dash cluster/bcm and not the actually ecu.
    either way a 3kw difference shouldnt make a noticable difference + wasnt the drop because of 2 extra cats being placed into the exhaust system to meet emissions?
    if ur really worried ask ur service guy to just upgrade the dash cluster software and leave the ecu alone
    anyway looks like the tunning software for these motors should be out soon so u can get your 3kw back + maybe more
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa Doctor Bob GTO Doctor Bob GTO
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    the fuel guage fix requires the ECU & instruments to be reflashed with updated software, you will get the same engine calibration with the updated fuel guage segment, The ECU MUST be reflashed as the original software is not compatible with the new istrument software
    the later software is not compatible with your car.
    the software version you have is the instrument cluster only, it has no bearing on the Engine software
    the dash reflash may not get back the missing options in a VY though, it definitely works in a VZ but not VY
    Black VZ SV6
    Dec 2005
    the paint is peeling from my handles too... the rear external door handle surounds. Did they do anything about it?
    Drive it
    Like ya stole it!
    VZ 175 Alloytech
    Oct 2006
    Smile
    Quote Originally Posted by Doctor Bob View Post
    the dash reflash may not get back the missing options in a VZ too, it definitely works in a VY but not VZ
    Hi Rob.
    Many thanks for clarifying all that.
    I am a little confused regarding whether the gauge reflash for missing display(s) will work on a VZ.
    In this After market headunit problems thread
    you mentioned that it will work in a VZ, maybe not in a VY...quoted below (my apologies for quoting out of context..)
    OK guys the answer is......
    if its a VZ take tha car to Holden & have them reflash the dash with the latest software (this may also include the Engine controller software) this should fix up the missing options.
    if its a VY there is no easy fix like that, it may be possible with some custom programming, but not sure
    Rob
    Door handles? My dealer is ordering new ones (painting them, then fit) - but were not too keen as it was pointed out that pressure washing was the culprit.
    My answer was how was I supposed to keep car clean on stage 4 restrictions here??, I hope they come through, otherwise I'll order some of the $22 NVU painted ones, or even caprice chrome ones...
    Thanks again...
    Laurie
    Doctor Bob's Avatar
    May 2004
    Quote Originally Posted by old holden v8 View Post
    Hi Rob.
    Rob
    Thanks again...
    Laurie
    yes my mistake the VZ is fixable the VY isnt.lol i will fix up the other post now
    VZ 175 Alloytech
    Oct 2006
    Thanks Rob.
    My dealer hadn't actually heard of the dash fix for the missing displays when a non OEM H/U is installed.....
    I'll report back on the results, in case others have the same problems.
    Thanks again.
    Laurie.
    Doctor Bob's Avatar
    May 2004
    VZ 175 Alloytech
    Oct 2006
    Finally some news to report.
    Dash displays ARE fixed with the reflash - obviously the ones that apply to sound system are non existant, but others are back..
    Fuel gauge after reflash of dash and ECU software is as bad as ever. Fuel gauge reads empty - display 0 KM left until empty - when approx. 15+ litres or so left....*sigh*..
    Laurie
    Doctor Bob's Avatar
    May 2004
    you may have a faulty sender, very few of the ones i have reflashed still have problems
    06 VZ SS 6.0Ltr
    Nov 2006
    Laurie
    My VZ shows empty when theres still 15l or so left. i would prefer it do this so I dont push it and run out of petrol.
    VZ 175 Alloytech
    Oct 2006
    Quote Originally Posted by dan-0 View Post
    Good point...
    But....... where I live there are not servo's on every corner. Also on long country trips it would be good to know, rather than guess on fuel remaining. If they (Holden) can get a fuel gauge reasonably accurate in my old HX utility - why can't they on a VZ wagon??
    But yes, I understand what you are saying in regards to the *big* push.
    Laurie
+ Reply to Thread
  1. VZ SV6 ECU Software Versions
    By steen in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-04-2009, 11:41 PM
  2. New Software Release
    By CSP in forum VE Holden Commodore (2006 - ?)
    Last Post: 29-01-2008, 10:03 PM
  3. VR V8 scanning software
    By VRdrift in forum Electrical Wiring / Questions
    Last Post: 29-01-2007, 09:19 PM
  4. GPS but no software
    By zeb00 in forum General
    Last Post: 12-10-2006, 09:26 PM
  5. Ecu - Pcm Software Version
    By Phil in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2003, 09:37 PM
