When lowering a VZ SV6 that already has Fe2 suspension in it with king spring super lows do u need to put a camber kit in it or does it already have one in it and do u need to change the front shocks to shorter ones
if you lower it it's best to get a wheel alignment done and as far as i know vx II+ have adjustable front rear .... otherwise you end up like mine, chops the insides out @ 5,000km's need to get that fixed soon too.... so many bills... so little money
___________________________________
Car: 07 VE SSV 6LTR L98 A6
Metalic Silver
ok i went to a guy to ask about a 2.5" exhaust system from the cats to put into my vz executive, but he said that it would just sound shit and just bark and scream when im looking for more of a beefy sound to it. So i was thinking what would be better, just do the 2.5" from the cats, or just take off the back muffler and replace it with 2.5" pipe from there
What would you recommend??
Thanks
i'd recommend making your own post
the front has enough camber movement in it to be sufficient and the rear only has a toe adjustment but if u put king spring super lows in it like i ave doen to my ssz itll b like the vt rear camber setting. it took me to do my springs 1.5hrs all 4.
in sayin that too. once u leave manufacturers specs u need an engineers certificate to proove that the lowering doesnt affect the cars intended functiona and u r permitted to show it upon rego inspection as it is a technical defect.
Still got your FE2 springs man?? In fact if you do the shocks too i will take the lot off your hands, pls let me know, cheers.
