Page 1 of 7 12345 ... LastLast
Results 1 to 25 of 158
Thread: VZ Alloytec 175 2 Hole mod
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    Default VZ Alloytec 175 2 Hole mod
    Hey all,
    Im sure this has been mentioned elsewhere BUT I thought I'd say I finally got round to doing the 2 hole mod.
    I decided it was time to clean the air box as it had some oil build up across the bottom from the K & N filter being a tad over-oiled.
    So while I was out I decided to do the "2 hole mod" which is so popular with V8's. Afterall, all it costs os $20 worth of materials and a few hours.
    I followed the instructions here -
    http://swingtan.customer.netspace.net.au/2hole.html
    At the bottom of the howto he says
    It’s much louder, if sound is anything to go by, it’s made a huge difference. But sound isn’t always a good test and I don’t have a dyno handy. The first time I really stuck the boot in though, there was a funny response. The car picked normally until it got to about 3500 RPM, then it was like the engine had VVT. It certainly picked up faster from 3500 to around 5000 and it wasn‘t just the feeling of being pressed back in the seat. I saw the tacho pick up faster from 3500
    So I took the alloytec out for a spin. First thing I notice, a growl at light acceleration! Nothing too much but definately different
    Onto the 50kph streets, yeh nothing too much.
    Get onto the freeway where we go from 50kph to 110kph. Stick the boot in and my lordy, what he said above! Nothing special at low revs, as is typical with the alloytec, but once the RPMs picked up and the air started being funneled into the engine bay the thing pressed me back into my seat like a turbo had just kicked in, or VVT had just kicked, or something had done something.
    On the freeway I tried overtaking. The 4 speed kicks back to 3rd, revs and takes off like theres no tomorrow!
    Moral of the story, if you've got a few hours free DO THIS!! I did it in between certain parts of the Indy telecast. Cost me $20 for 1 meter of 90mm diameter plumbing pipe and some sandpaper from bunnings. Just gotta flare the ends of the 2 pieces of pipe and paint them matt black tomorrow for that factory look, but you will definately notice an increase of some sort.
    colk is offline VZ 3.6
    VZ 3.6 Exec
    Aug 2007
    VT Berlina 07's Avatar
    VT Berlina 07 is offline 15.37 @ 147 KPH
    96 EF2 Futura I6 Auto
    Apr 2007
    Sydney, NSW
    haha, i did the same with mine (ecotec but) cant say theres any diff in power but the noise is louder
    96 EF2 Futura I6 Auto Sedan Superlows Front/Rear with Monroe GT Sport's, EL XR Front, 16" Tickford Wheels with 225/50 Wanlis, 5% Tint, Sony Headunit/ 6 1/2" 190w Speaker's, Fram Air Filter/XR6T Snorkle, Pacemaker 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD 15.37 @ 147 KPH
    GOTMYN's Avatar
    GOTMYN is offline Stab it and Steer...
    Whippled 5.7, VE SV6, GU Patrol 3.0DI
    Sep 2006
    Mornington, Vic
    Funny you say that, I just did my Eco... recently and This week had my usual 0-100 Race with a mate from work in his 190kw VZ SV6, it is normally me jumping him off the line, and then it evens out with me gaining a car length or two on him before we back off to get back to the 80kmh speed limit, but this week, even he pointed out, that when I shifted to second and started to gain speed, I shat all over him... Like 6 car lengths.... Thanks Home made CAI... so it seems!!
    If I'm not pulling Toyota's out of the Bush, I'm pulling 12's in the Sig :-)
    Torquative's Avatar
    Jun 2005
    Im definately impressed, as Ive said, and good to read so are others!
    I never knew an Alloytec could create a growling noise at low revs and for so cheap. Still sounds awesome taking off from a set of lights
    doy ou guys run K+N filters or just the standard paper ones? just curious
    Sep 2007
    Quote Originally Posted by Y2kGoofball View Post
    Now you've had a week of daily driving how's the fuel economy? Any difference? The performance still there?
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    VZ SV6
    Aug 2007
    I did this mod a few months back and I definitely noticed a difference. Although its not much, for the cost its worth the effort! As for sucking in hot air, if you make the pipes as long as possible then the ends actually sit behind the headlight so it only sucks in cool air not all the air from the engine bay. Here's a couple of pics from when I did mine
    Attached Thumbnails Attached Thumbnails VZ Alloytec 175 2 Hole mod-dsc03898.jpg   VZ Alloytec 175 2 Hole mod-dsc04136edit.jpg
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    did mine the other day and it cost a big fat $0.00 cos i snaked the pipe off a job. it kinda feels a little smoother and it is alot louder but no louder then when you remove the snorkel.
    dunno who asked the question RE filter... but mine is a normal paper type
    VS Acclaim V6
    May 2005
    Can this be done on a VS?? Reason I asked because the air box is smaller. Not sure if this will make a big difference.
    Torquative's Avatar
    Jun 2005
    the car went into the mechanics on Saturday for a service and the guys asked me "whats different about your car".
    They told me they service many VZ's and they took mine for a spin round the block, put the foot into it to give it a good clean out and noticed an "awesome vaccum roar type sound while the car just took off from under me like Ive never experienced in a VZ V6". They then said "we had a good look when we got it back, its a stock exhaust and we can see theres no pod filter, whats different?" (coz I told them to leave the air filter alone as its a K and N so they had no reason to rip the lid off the air box)
    With the radiator shroud back on you cant see the airbox mod so it does look stock which is good too!!
    Apr 2007
    Sydney, NSW
    lol i know, its sounds good. it makes people look. eg when in 2nd gear @ about 50ks and nail it theres that sound
    andrewmac's Avatar
    andrewmac is offline Not to be trusted
    S2 VE SS
    Jul 2005
    VZ 3.6 Exec
    Aug 2007
    does anyone know if it effects holden warrenty? I am getting the dreaded vz knock in the diff and dont want to give em any reason to void warrenty? although then again modding the air intake cannot effect anything with the diff or trans so it shouldn't be an issue?
  15. #15
    Sep 2007
    Quote Originally Posted by colk View Post
    Maybe waiting until your diff gets sorted would be the better option.
  16. #16
    VZ SS 6 SPEED MANUAL
    Apr 2007
    WA
    Quote Originally Posted by =SKB= View Post
    Yeah i have to agree, if it was me i wouldnt be doing it until, the warrenty is over, just incase
  17. #17
    VZ SV6
    Apr 2007
    It is a cheap mod. Buy another airbox and do the mod to it and keep a spare for services or warranty.
  18. #18
    VZ 3.6 Exec
    Aug 2007
    Good thinking, will do
    Quote Originally Posted by -SV6- View Post
  19. #19
    VZ Ute/VT Sedan
    Jun 2005
    Townsville QLD
    Has anyone dynoed this mod? What might be nice is a series of runs from stock with stock airfliter, stock box with K&N, K&N with 1 ram tube, K&N with 2 ram tubes.
    It does sound like nearly free HP though, and I never look a gift horse in the mouth!!!!
  20. #20
    VZ 5.7l
    Sep 2007
    Newcastle
    Quote Originally Posted by lacy18 View Post
    Yes it will be sucking hot air you have to fit the shroud that comes standard on the VY After shroud then you will notice difference 2 fold....
    Just took some pics off the phone camera, so they are a little grainy. As you can see the cut out is towards the upper part of the shroud, this shroud was part # 92096849 (only came with the single hole to suit VZ Monaro). but all that has to be done is trim away the section and it should fit in. It will take some squeezing to get it into place and fit snug behind the headlight. I had to get some extra foam tape to seal everything up nice and tight.
    These photos will show you how to do the Monaro Cold Air Intake You have to cut 2nd hole in the shroud.
    Hope this helps guys and happy modding
  21. #21
    VZ SV6
    Dec 2006
    Hey guys!
    Is there a way that the two hole mod can be done using flexible piping to capture cold air from the big voids in the lower front of an SV6??
    Is there enough room at the side of the radiator to run the piping around, anyone know??
    I guess what im saying is, is behind the headlight the only place that you can run the pipe to draw cold air??
  22. #22
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    i have often thought about that, but never actually got off my arse to check it out properly
  23. #23
    Torquative's Avatar
    Jun 2005
    dunno bout SV6 but when i looked at doing that with the 175 it would need some pretty heat resistant piping, because it will touch the radiator hose at some point, and that gets bloody hot!
    I think it can be done, but as I said, needs to have fairly heat resistant hose
  24. #24
    2005 VZ SS Ute
    Sep 2006
    Default VZ - V6 Two hole mod
    Hey CMA
    - I did the Two hole mod the other weekend on my 2005 VZ ute using flexi-pipe.
    3" Pipe cost $30 from Super-cheap and comes with a couple of tension clamps (not needed for Two hole mod)
    I drilled into the SIDE of the air-box as opposed to the front (side furthest from engine), and then ran the flexi-pipe out and down under the head light.
    The head light has to come out to get the pipe through, and then the pipe has to be squished a wee bit to get the light back in.
    From there it is pinned up beside the horn to suck cold air from the small grill hole to the right of the number plate. (This grill is normally filled with a solid plastic facia, but I have ripped them out and put steel mesh in instead.
    Will get a better line-up with the grill hole when I move the horn out of the way this weekend, but currently getting a dramatic improvement to pick-up around 3500 - 5000 rpm.
  25. #25
    bludeck's Avatar
    bludeck is offline Wishlist = Blowa
    VZ Wagz
    Dec 2007
    Gold Coast
    Mod completed! soiunds abit deeper unnder acceleration didnt notice any power or economy gains tho :S
  1. key hole????
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2008, 03:55 PM
  2. Hole, what is it?
    By Chirpstr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2007, 05:50 PM
  3. wat hole
    By vn chicky in forum Jokes/Humour
    Last Post: 19-04-2007, 10:41 PM
  4. Wrecking Hole Vk Sl
    By VK SLEEPER in forum Parts And Other Items For Sale
    Last Post: 19-01-2006, 09:10 AM
  5. Alloytec and Alloytec 190 Engine Specs and Details
    By Gobbles in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-06-2005, 05:24 PM
