Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VZ Holden Commodore (2004 - 2006)
VZ Holden Commodore (2004 - 2006) Talk about anything relating to the VZ Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 02-11-2007, 07:59 PM
Ride: VZ SV6 & VXII S
Trade Rating: (0)
MyPetFly Executive
Default HELP - SRS Airbag Fault
Hi Guys,
I think I stuffed up. I have been pulling the centre console in and out several times over the last few days as I am installing a carputer.
Anyway, tonight I pulled the front passenger seat out as well (to mount the carputer under) and when I put it all back together and turned the ignition on the SRS alarm goes off (beeping tune) and I get a message on the dash saying SRS Airbag Fault.
I am pretty careful the way I do things but am not an auto electrician. What could I have done wrong?
I should say that the wiring for the carputer was all done, finished and tested yesterday BEFORE this fault occurred this evening. All I did tonight was pull out the passenger seat and centre console - I didn't add any new wiring or modify any that I had already done.
I did turn the ignition back on to ACC before I put the seat back in and that is when the warning first came up. Could turning the ignition on with the seat out (and wires for seat electrics unplugged) have cause this fault?
Would really appreciate any advice. I don't think I will sleep well tonight!
Thanks
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 02-11-2007, 08:11 PM
daron's Avatar
Ride: vt 2000 series 2
Trade Rating: (0)
daron Berlina
setting off the warning lights is easy of you had it unplugged and turned key back on
make sure its all plugged back in and go for a short drive it will reset itsef but remeber it stores in computer so next service they will tell you ya have a fault and will need 49776529840 bux to fix it
__________________
stay tuned for next cruise here
never drive faster than your guardian angel can fly
  #3
Old 02-11-2007, 09:07 PM
Trade Rating: (0)
MyPetFly Executive
Thank Daron,
Going for a drive now as I won't be able to sleep tonight if I don't give it a try.
I've only just realised that it was the passenger seat SRS that I unplugged when I removed the seat. Initially (as per my original post) I thought it was the electrics for the seat adjustment (which the passenger side doesn't have).
Will post the result of my little drive.
  #4
Old 02-11-2007, 09:10 PM
daron's Avatar
Trade Rating: (0)
daron Berlina
if it doesnt go out youll need to go to holdens and have it cleared
its not broked normally costs 40 bux max or free if ya find a nice holden man
__________________
  #5
Old 02-11-2007, 09:37 PM
Trade Rating: (0)
MyPetFly Executive
Unfortunately it didn't clear. I'm booked in next week for a warranty repair on my stereo head unit (plastic cracked) so I will see if they will reset it for me for nix.
I'm beginning to wish I hadn't given my local Holden dealer a serve about their poor service when I went in 4 weeks ago to have another warranty repair looked at. I have no doubt they will remember me!
Can my local mechanic reset these things? I know in the past he has said he has all the gadgets to hook up to the cars computer?
  #6
Old 02-11-2007, 09:56 PM
daron's Avatar
Trade Rating: (0)
daron Berlina
yes lots local machanics have the tech 2 or some gadget that can clear the codes
__________________
  #7
Old 03-11-2007, 01:19 AM
goVZ's Avatar
VE? Very Excellent!!!
Ride: parents' Toyota Hilux SR5 dual cab 4WD
Trade Rating: (0)
goVZ Berlina
Yeah, if your mechanic has access to a Tech 2 they can do it no problemo. It would've been set off when you disconnected the airbag sensor...nothing unusual.
__________________
"There's nothing quite like a Holden"
  #8
Old 03-11-2007, 10:45 PM
Trade Rating: (0)
MyPetFly Executive
Just a little update . . . . I pulled the SRS airbag fuse out whilst I have had the front passenger seat out. This stops the SRS fault alarm going off and the system check says "Check OK" at the end. Unfortunately the red SRS on the instrument panel doesn't go away and I still don't know if the alarms are going to come back once I put the seat back in and put the SRS fuse back in!
  #9
Old 04-11-2007, 01:53 AM
naf33n's Avatar
go
Ride: vz sv6 M6
Trade Rating: (0)
naf33n Berlina
try holding up and down on the mode switch when turnin on ignition it should flash and beep and say something bout fault memory or something.then hold set until it beeps. that clears service reminders and faults etc so it might clear the srs
  #10
Old 04-11-2007, 07:01 AM
impulsesv6's Avatar
OUT ON PAROLE
Ride: Supercharged Alloytec
Trade Rating: (0)
impulsesv6 Executive
may srs came up when i pulled out my cluster, took it to holden and said "raqc said it was because of the flat battery in the car" - and they cleared codes for free
__________________
TEAM RAPTOR SUPERCHARGERS
  #11
Old 04-11-2007, 11:10 AM
andyman's Avatar
Master Hippo.
Ride: 05' VZ Wagon, 04 Husky TE250 & 05 Husky TE450
andyman Monaroandyman Monaro
the passenger seat has a sensor in it to detect when a person is sitting in it for the computer to know whether to set off the air bag in an accident or not (SV6 also has an airbag in the seat?)
so when you disconnected the harness from the seat when you pulled it out and leaving the battery connected it set the code, you will have to go to holden to be cleared as it wont automatically reset itself
__________________
VZ Wagon - Starting to get there
>>>>>HERE<<<<<
Black 18z, Hell Yeah
My New 05' Husky TE450
--===-- My Old 04' Husky Te250
Quote:
Originally Posted by Hamish & Andy
Whats it like firing a big gun on a tank?
"like having a massive penis that shoots fireworks"
Like what you read, Then hit the scales
  #12
Old 04-11-2007, 07:01 PM
Trade Rating: (0)
MyPetFly Executive
Definitely going to have to go to Holden (unless my mate who is a mechanic can reset it for me).
I've tried all the tricks about but none of them work. The good news is that my carputer is now successfully installed an working perfectly.
  #13
Old 06-11-2007, 09:33 AM
Trade Rating: (0)
MyPetFly Executive
Just thought I would post a result here for future reference. I went to see my friend this morning that is a mechanic and he has a thing called a "Scan Tool" that he can use to reset the error codes. Took him (actually his apprentice) 5 mins to clear the codes. It didn't even cost me a 6 pack of beer.
The good news is that there is an alternative to Holden to fix these things.
  #14
Old 06-11-2007, 12:14 PM
impulsesv6's Avatar
OUT ON PAROLE
Trade Rating: (0)
yep, preety much every decent workshow has scan tools, they help diagnose problems with the new cars, they give the operator an indication of what the car computer is picking up of its sensors
__________________
Digg this Post!
