Hey all!
Recently got a VZ SV6 5 speed auto, was reading through the books for it and noticed it says the 5 speed auto transmission is sealed for life, please explain...
its easy, every 100k or whenever just remove the bung or pull the sump off and drain, you can then refill through the bung in the bottom
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
there is a drain plug and there is a filler plug, i havnt played around with one yet but im sure you can still change the fluid
Haven't seen the filler plug thats all. buT havent had a good look yet either.
There must be a filler and drain plugs as the trans fluid should be changed every 90,000 k's according to the specs.
Just a question on the trans, anyone get a click when selecting reverse? Noticed it on mine, not so much when engine/trans is cold but when it has been driven for a while?
Hi,
I am assuming you have a dip stick for the transmission. If so, then that is where you can refill it.
Deltak
No, there is no dipstick on the 5 speed auto box, only the 4 speed has a dipstick
Does anyone know.. when driving in "D" does it hold 4th gear until it hits about 70-80 k/hr then change to 5th??
Just took the Workshop SV6 into holden to get the fuel gage fixed under warranty and they flashed in a update for the 5 speed Auto while it was there, now the gears change very quickly and hold longer, its much better to drive, I was disapointed with its performance compared to my manuel ute, but now it actually performs really well
I recommend it for all those with 5 speed autos, just ring your holden dealer and tell them that your transmission is shifting wierd and revs out to much, they will then flash in the updated software for free under warranty
