LS1 / LS2 Performance Modifications
- Tuning:
http://forums.justcommodores.com.au/...less-tune.html
http://forums.justcommodores.com.au/...edit-melb.html
http://forums.justcommodores.com.au/...questions.html
http://forums.justcommodores.com.au/...melbourne.html
http://forums.justcommodores.com.au/...edit-tune.html
http://forums.justcommodores.com.au/...tune-edit.html
http://forums.justcommodores.com.au/...-fuel-eco.html
http://forums.justcommodores.com.au/...-tune-not.html
http://forums.justcommodores.com.au/...der-edits.html
http://forums.justcommodores.com.au/...s-tunning.html
- Clutch:
http://forums.justcommodores.com.au/...vy-clutch.html
http://forums.justcommodores.com.au/...nd-clutch.html
- Forced Induction:
http://forums.justcommodores.com.au/...ask-again.html
http://forums.justcommodores.com.au/...s-gen-3-a.html
http://forums.justcommodores.com.au/...-sc-sytem.html
http://forums.justcommodores.com.au/...sport-not.html
- Exhaust:
http://forums.justcommodores.com.au/...-question.html
http://forums.justcommodores.com.au/...usts-5-7l.html
http://forums.justcommodores.com.au/...resonator.html
http://forums.justcommodores.com.au/...ust-sizes.html
http://forums.justcommodores.com.au/...t-systems.html
L76 Exhaust Upgrade
gen 3 zorst
SSZ Exhaust (LS1)
SS VZ Exhaust
- Differential:
http://forums.justcommodores.com.au/...iff-gears.html
- Intake:
http://forums.justcommodores.com.au/...od-vs-cai.html
http://forums.justcommodores.com.au/...-gear-ls1.html
Why not to buy a K&N filter
Alloytec Performance Modifications
- Clutch:
Clutch !!!!!
http://forums.justcommodores.com.au/...s-arrived.html
SV6 gets a new clutch...aftermarket style.
- Tuning:
190kW Alloytec tune results!
VZ tune, where is the 48kw gone
VZ SV6 Test.. MAF vs MAFLESS
VCM Tunning Software
Powerchip Tune For Alloytec
Dyno Tuning
VZ Computer Chip
tune first?
- Forced Induction:
Supercharging the VZ 6
Supercharger on Alloytech?
Turbo For The Alloytech
vz v6 turbo kit
vz v6 turbo
Supercharger or Turbo
VZ SV6 Supercharger
Confirmed- SV6 to be Chargd
- Exhaust:
VZ Ute Exhaust (V6)
Dual tip mufflers
Extractors/Headers kw gains ???
http://forums.justcommodores.com.au/...h-exhaust.html
What is the Difference between Exhaust Systems
VZ Exec 2005 175 exhaust
alloytech exhaust (175)
VZ Sv6 Exhaust
sv6 exhaust
Exhaust for VZ
Alloytec190 Exhaust Note
http://forums.justcommodores.com.au/...t-s-worth.html
Alloytec Exhaust Fun :)
exhaust quote
What kind of cat back exaust????
- Differential
diff gears
Diff Gears Problem
- Intake:
VZ Alloytec 175 2 Hole mod
SS Inductions VS. DIY Alternative
VZ SS Cold Air Intake/Short Shifter
Cold Air Induction for 2005 175 Executive
Home Made Cold Air Intake..
k&n intake kit
HSV Intake
Air Intake Restriction on 190kw
K&N filter... worth it?
SS Inductions
2005 SV6 - CAI \ MAF Mods - help me out ?
Cai For The Sv6,
SS Inductions
2 Hole Mod Query
- Brakes:
HBD Brakes
Brake Upgrades
General Modifications
- Interior Modification:
Led Dash Lighting
VY/VZ Guage Pods
Single LCD -> Triple LCD Dash upgrade
Calais cup holders
Painting Dash Panels
- Wheels:
18" wheels on a VZ
what wheels to put on my ute
will these wheels fit?
optional wheels
Show us your rollers:
VE Clubby Wheels on a VZ SV6
Wheels for Crewman SS
Question for Ute owners with 19s and lowered
VZ SS rims
- Tyres:
Tyre advice
Tyre recommendations
New Tyres on SV6
Fat Tyres!!!
Tyres - 205 or 225?
VZ SV6 tyres
Tyres
- Stereo:
is it hard to change VZ exec speakers
stereo
VZ Sterio Upgrade (UTE)
Stereo Full Volume
Sv6 rear speaker wiring
Ebay Fascia Kits
VZ stereo
iPod for SV6
Is this possible or am I dreaming? LCD monitor mounting.
VZ Monaro Stero
- Lowering Sedan:
Lowering an SV6
Lowering Of VZ Commodore
How Low Should I Go ??
King Springs
Lowering with King Springs
Anyone Lowered a SV6?
Suspension differences
- Lowering Wagon:
lowering
- Lowering Ute:
Lowering an 06 VZ SS ute
early vz ute lowering just a question
question about lowering
Lowering a VZ Ute
Thunder is lowered
- Alloytec Engine Cover:
Alloytec engine covers
painting engine covers
i painted my engine covers
- Alloytec LPG Conversion:
alloytec on lpg??
Gas On Alloytec 190
SV6 on Injected Gas now
LPG Alloytec
- Reverse Parking Sensors and Camera:
Reverse camera /monitor
Reverse sensors for vz ute - crewman
Reverse parking sensors
Miscellaneous
- Transmission and Clutch Problems (LS1/LS2 6 Speed Manual):
SS 6speed clunky box
GRRRR... New Thunder SS, Clutch / Gearbox Issues
VZ 6L 6spd gearbox noises
Clutch Problem
New Clutch @ 800 kms
- Transmission and Clutch Problems (Alloytec 6 Speed Manual):
VZ V6 6 Speed Gearbox - Your Experiences ?
6 sp manual Gearbox problems
SV6 6 speed - giving real trouble now, anyone else??? :(
Clutch Probs
clutch problems
Clutch !!!!!
Not all THUMPS are normal
- Transmission Problems (Alloytec 4 and 5 Speed Automatics):
sv6 engine squeal?!?!?
VZ SV6 - Auto Transmission
http://forums.justcommodores.com.au/...v6-auto-s.html
VZ Commodore 4Spd Auto Thud Sound
VZ Thump from 2nd to 3rd gear
Gearbox noises
Clunk when shifting 2-3
- Alloytec Differential Problems:
SV6 Mechanical Issues
Diff Problems
Rear diff/axle noise
Adventra Rear end whine.
SV6 Diff Problem
- Fuel Gauge Problem:
VZ Fuel Gauge Problem
- Holden Recalls:
*** ANNOUNCEMENT - VZ Safety Recall ***
GM Holden Safety Recall-side air bags
- Dealer Servicing:
Is this too much?
How do I get the most out of Holden service?
What did you pay for your Service?
**WARNING** VZ V6 Owners
15000km service interval means full syn oil only
20K service?
45,000 Service
15K service
15000K Service- Is it going to matter if i go over?
- Home Servicing:
Collant and oil filter
drain coolant
VZ alternative servicing options
Oils Aint Oils
10w-?
Servicing Instructions?
- Tyre Wear, Wheel Balancing, and Rotating:
How often to rotate and balance tyres ?
Vz rear tyre wear
Camber and tyre wear
- Buying a VZ:
Buying a SV6
Buying a VZ
Buying a VZ at Auction
Independent Rear + Castor/Camber Kit + Lowered Coils
- LS1/LS2 Fuel Economy:
VZ SS fuel consumption
What Kms to a tank of Juice
VZ SS Fuel Consumption
6l 6 speed fuel economy
Is fuel a real Bi*%& in the vz ss
- Alloytec Fuel Economy:
Fuel Consumption
VZ fuel economy
http://forums.justcommodores.com.au/...-vz-175-a.html
Fuel Economy Per Tank Of Fuel
VZ V6 Manual Fuel Consumption
VZ Commodore How To’s
- VZ SV6/SS Bumper Removal:
- How to Remove Dash and Centre Console:
http://forums.justcommodores.com.au/...ole-vy-vz.html
- How to Replace Indicator Stalk:
http://forums.justcommodores.com.au/...-stalk-vy.html
Thread Updated.
i thought it was big before, its huge now!!
i encourage everyone to give positive rep points for this, it is an awesome effort!
massive help to a newb. cheers
Top thread..
Thanks Bill......
Hey VZed owners im after a work car and looking at an 05 early build VZ with roughly 90-110,000kms on the clock. Having not seen many VzeD v6s with more than 50,000... im asking what some owners think of thier cars that are approaching this milage. Any tips on what to look for? My first assumption is that it would be better to get a 100,000+ km VZ, only because it would have had a 100,000 service and report already done by holdens?
Any more to add?
Many thanks
Frank
Edit: Mods plz move to VZ general. Thanks.![]()
Azzurro
very nice,
thanks alot for your effort...
I have a Vz sv6 190kw edition, and I want to know some information about a engine swap... if som1 could give me advice please?
Im looking to buy a Ls6 or Ls7 small block crate engine to put in my car..
-will it fit in so i can still have the standard bonet on?
-i understand that i will need a new transmition block and exhaust system.
-if i do get this new engine will my paddle shift system still work? after a computer re-boot?
-iv been tossing up between this engine change and getting a supercharger kit.. and because my car is at 120,000k's im thinking putting a supercharger on an old motor isnt the best thing to do. right?
ur help and advice would be great thankyou =)
does anyone know how to bleed the cooling system in a vz ls1 5.7. I recently has to change top and bottom hoses, since then the water level every morning is low in the radiator???
selling a vz sv6 190kw on injected gas is a write off if interested call or text 0413621660
I own a 2005 VZ SV6 and am not really the mechanic type, but I would love to at least be able to do the basic servicing things and "man up" a little.
I am wondering if there is a pdf copy of a general service / repair manual on this forum somwhere. I have tried to search, but to no avail...
If anyone can point me in the right direction, I would greatly appreciate it
do monaro lights fit a vz commodore??
I have a svz comodore and my power train light has come on i took it to holden and they told me it was my o2 sensor,is it easy to replace?And is there more than 1 sensor?
hi everyone i have a vz 2006 exec wagon was just wondering how do i go about getting the steering wheel button controls to light up thanx guys
what sort of springs should i put in my vz wagon to lower it thanx
will a vz hsv cluster work in my vz v6 executive
Hi, i've got a 06 VZ Wagon with the build and compliance date at 08/06. Does this make it a MY06 or MY07. Would appreciate some help on this. Thanks.
Hi, just wondering if the ECU on an 2004 Alloytec 175 VZ commodore can be replaced at home with a new/secondhand one or does it need a software re load and or configuring to my vehicle???
Thanks in anticipation.
Dave M.
Yes there is one, I bought it about 2 weeks ago, it cost about $60 though, covers everything from servicing to trouble shooting, and the one i have covers from VT's through to VZ's V8's and V6's its called commodore 'V6 and V8 1997-2006'.. service and repaor manual produced by gregorys, hope thats help full lol
if thats not enough info im sure i could post a pic of the fron cover.
None of the links work. Please advise????
hi
having problems with starting long cranking but will start.
and does anyone no were the crank angle sensor is.
many thanks
Hey guys
I have a VZ commo and im wanting to buy seat covers but i dont know what size id have to get and i cant find the stupid thing on the car.
Thnaks, linda
