Hi everyone i dont know wether its an fault (or soon to be) or software error glitch...
On turning on the ignition you always get the software check on the LCD display and all the other warning indicator lamps battery, ABS, SRS, Handbrake and Seatbelt.
On starting the engine the Battery and ABS clear within 1 to 2 seconds but the SRS continues to stay on for 15 sec then clear
Origanily the all turned of pretty much together, is this an sofware glitch or an appearing fault on the airbags..
This is on an Oct 04 SV6
Thanks
Thanks
