OH, wouldnt happen to have any that you want to let go now
Haha fair enough, cheers anyway
got myself a ck-7w kit nice and cheap and im trying to wire it up to test it in my care but im running into trouble getting power to it.
Might be stupid question but where do i connect the nokia cable set to the car. does it go into the holden plug under the glove box?
ok, i have found the power and the ground im just not sure which is the MUTE and the IGNS
managed to find the MUTE lead but when i get a call the radio mutes but then doesnt unmute. have i dont something wrong or is this some other problem
Have you got the button hooked up?
guys i just bought a nokia kit off ebay. looking to install, think i might be ok with all the info posted. I tried to get the extra parts from holden so i can use the factory button but they told me they only sell the full bloutooth kit and not parts, any ideas?
Hi guys, do i need to pull centre console out to wire in the factory button? I dont see how to get the wires up through the gap and connect to button otherwise. Also my button seems to be loose in the bezel with a gap around it. Is this normal? I have the single hole bezel.
i pull mine out. I ran the button from behind my glovebox where the box was so it was all hidden away. Plus i needed power for the light which i got from the cig. lighter, all alot easier when the console is out.
Your button shouldn't be loose, check again to make sure you have it in the bezel correctly.
couple of questions.
How do i remove centre console?
I dont have a cigarette lighter, only charging power in glove box so where can i get power for lights? And how do i do this, do i slice a cable and join another cable to this?
Installed a bluetooth in my car no problems. Tryed to install one in my old mans car and problems.
1st; if the radio/cd is off and a call comes through the radio doesn't turn on and the call doesnt come through the speakers? the radio does cut out when a call comes through if it is on.
2nd; the radio controls on the steering wheel now dont work?
any suggestions would be great.
quick question does anyone know the full pin outs of the buton what i wont to try to do is use the nokia buttons light for the holden button light so it flashs when pairing like the nokia one does
just read the posts, can you have an answer and hangup button with the nokia kit? useing factory answer buttons, reason for question is i saw someone use this for a samsung blue tooth kit, or doesn't work for the nokia?
oh ok, so you use just the one button for answer, hang up and for voice activation?
can you wire the nokia kit to have the answer button and a seperate hang up button?
I just installed an alpine cde-104bti head unit. Full blue tooth built in, can get it for around $430. If you are looking at upgrading your head unit and want bluetooth handsfree I can highly reccomend it, excellent head unit with great bluetooth functionality.
DOnt know why you would bother with the factory unit when u can get this setup for cheaper....
Hey guys - GREAT information here and I'm well on my way to getting one of these puppies installed in my car. I'm wondering where you guys are wiring the pins on the button to make the lamp illuminate... Has anybody connected these pins to the extra pins from the Nokia? Why are people wiring them up to the cig lighter? I don't want mine to be on all the time I just want it to come on as a status indicator when in calls -- or wire it into the same power source that lights up the buttons for the power windows when the headlights are on. Any ideas?
Thanks!
Power window lights are on all the time in my VZ whether the lights are on or not.
As soon as you unlock the car the pwr/wnd lights come on.
Why do you only want the phone switch light to come on when you get a call won't the ringing thru the radio tell you that you have a call coming, besides the switch isn't in the best position to notice when the light comes on or off.
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
